tell me what u guys think sorry for bad picture.. cell phone pic
dose this look good?? im not done quite yet got put jb weld around the flange part where it meets the oil pan
i got the oil line today from a awd talon
Re: tell me what u guys think sorry for bad picture.. cell phone pic (EJ8CIVIC)
i would use high temp silicone in between pan and flange over jb weld.. jb is not flexible and will crack off and leak.. or make a gasket out of universal gasket paper... make sure that line isnt rusted bad or about to crack in any spots too or u will regret it later.. make sure u got loctite on them bolts too. u dont want a nut falling into the oil pan
Re: (EJ8CIVIC)
u def need a gasket or it will leak like crazy.. trust me i tried stuff like that alot.. at least clean it really good and use automotive silicone as a gasket but it still may leak.. id use paper.. it does look really high up.. also. if its too high just cut the flex part out and use rubber heater hose to reconnect both ends.. thats what i run on all my turbo cars and its fine. just dont kink the hose
Re: (97grnrs)
i know bout the flex part that was going be my 2nd is cuting it off..oo yea i got lock washer on the inside.... well im happy that it looks good nobody has said nething bad so im glade
i bad glade when i get this sohc turbo in jus taling my time and getn parts
Re: (EJ8CIVIC)
i can almost gaurentee its gonna be too high.. so u may as well find a rubber hose that will fit snugly around it for when u cut it.. i had a greddy mani and from turbo to oil drain on pan it was only like a 2" drop
Re: (97grnrs)
cool man thanks for the info i keep that in mind when i do mine
umm anything else i need to ask or do u guys need to ask anything to hep me out in my build
datdurtyboi
02-08-2014 02:38 PM
