Built Ls/Vtec with Tube Style Mani & 60 Trim Questions.
Ok I have a Hermsfab.com Tube style manifold that i bought last summer and Never ran. It was going to be used on a STOCK Poorman's Type R set up but I ended up building a set up.
What I want to know is my motor set up a Over Kill for the Mani and Turbo I have.
Here is the List set up. Im not shooting for anything over 500hp or under 400hp.
Gsr Head:
Ported/Polished
Manley Valves 1mm
REV Valvesprings
Crower Retainers
ITR cams
Skunk2 6 bolt cam gears
Edelbrock Victor X Manifold
Ls Block:
Benson Sleeved B18b1 84mm
Ls Crank Knife edged
Eagle Rods
Ross 9:3:1
Oem Bearings
Arp Rod bolts
Golden Eagle LsVtec kit
60 trim .48 A/R turbo
Hermsfab.com Tube style mani ---- Honda-Tech Sponcer
Hermsfab.com 3inch Dp ---- Honda-Tech Sponcer
Tial Wastegate 38mm
Tial BOV
2.5 inch piping w/T-Bolt Clamps
28X8X3 FMIC
TurboXs MBC
780cc injectors
ARP Head Studs
STR Fuel Rail
Braided Fuel Lines
Automotive FPR
P28/ S200b----Dump'n for a S300
New GSR Water Pump
New GSR Timing Belt
All new Seals
Gsr Head:
Ported/Polished
Manley Valves 1mm
REV Valvesprings
Crower Retainers
ITR cams
Ls Block:
Eagle Rods
Ross 9:3:1
Oem Bearings
Arp Rod bolts
Tial Wastegate 38mm
Tial BOV
28X8X3 FMIC
TurboXs MBC
780cc injectors
ARP Head Studs
STR Fuel Rail
Braided Fuel Lines
Automotive FPR
New GSR Water Pump
New GSR Timing Belt
All new Seals
