Limp Mode! Cluless...searched...still lost
Old 02-18-2007, 02:47 PM
RangerHatch's Avatar
Default Limp Mode! Cluless...searched...still lost
Ok so i was driving back from GA to MN. I got into state and 2 days later it dropped to almost a record low. I went to start my car one morning and it would just crank. My battery died from it being cold and trying to turn it over. I threw on a battery charger and still it was just to cold. I ended up getting the car into the garage and changing the oil. I was trying to crank it over and thats all it would do until finally i got it to start. As soon as it started the check engine light came on and car was in limp mode. My setup is:
95 Civic Dx w. Jdm B16a
garrett t3/to4e 60 trim turbo
Tial 38 mm blue to wastegate
walbro 255 lph fuel pump
Greddy type rs bov
dsm 450cc injectors
tuned with uberdata
The car wont go past 3K in any gear. It is running insanly rich at idle, also my vac has slowly gone down from 20 (when car was ok) and now is around 5. We re-did all vac lines and little tests but still have questions. Can anyone please help give me some ideas, suggestions?!?! Thanks
Old 02-18-2007, 02:59 PM
Default Re: Limp Mode! Cluless...searched...still lost (RangerHatch)
Also when i try and get the CEL code out using the "paper clip" method my check engine light just stays on! Doesnt make any flashes or anything. Just stays solid...please help!
Old 02-18-2007, 04:57 PM
coneheadsracing's Avatar
Re burn your program.
Old 02-18-2007, 07:57 PM
ghostskinner's Avatar
Default Re: Limp Mode! Cluless...searched...still lost (coneheadsracing)
sounds like your ecu has gone bad but check your program and your solders just to be safe same thing just happened to me it was the solders they werent done properly
Old 02-19-2007, 09:00 AM
hold your breath's Avatar
check your map sensor. make sure it not clogged.
Old 02-19-2007, 10:06 AM
* B A N N E D *
Pnoyej6's Avatar
Default Re: Limp Mode! Cluless...searched...still lost (hold your breath)
check your spark plugs. Mine did the same thing keep cranking and but wont turn over on my lsvtec turbo. Also on my old gsr setup. same thing happen. i tried to jump code but solid cel no flashes. It ended up ,water going on my ecu and it went bad.
Old 02-24-2007, 08:25 AM
Default Re: Limp Mode! Cluless...searched...still lost (PnoyLSV-T)
Thanks guys for the help. I changed the spark plugs when that happened. So those are fine. I took out the ecu and pulled the chip out....everything seemed to be fine and i was clueless. Waited a day or 2 and went to plug it in just to let my car warm up in the cold and everything is now fine!!! WTF someone please explain if you can haha. So i guess you can say things worked out fine!
Old 02-24-2007, 01:52 PM
g23_ej1's Avatar
did you try to reset your ecu at all?? i know when its real cold out my car runs real rich.. i have a similar setup to yours.. resetting your ecu should've been the first thing you did glad to hear it all worked out for you
Old 02-24-2007, 05:49 PM
cpl rampage's Avatar
it could just be that a solder joint is poor, and lost contact when it cooled, and when u pulled the chip, it connected beter, just my .02
Old 02-24-2007, 09:15 PM
Default Re: (cpl rampage)
ya i tried to reset the ecu by connecting the battery cables for a little while while i was doing little maintence. In the cold it was running so rich it wasnt reading really on my guage that it was just all the way rich. I dunno maybe when i pulled the chip and put it back maybe something wasnt touching or connected right! thank god i went to just warm up may car before i got a whole new ECU and changed my chip! saved myself about 650$
Jdm50
08-04-2018 08:41 PM
firefox15
Honda Civic (2001 - 2005)
05-21-2014 04:30 PM
bigJOE671
09-17-2012 04:55 PM
coot_er
16
03-17-2005 07:54 AM
Quick Reply: Limp Mode! Cluless...searched...still lost
