over heating at WOT???
Old Feb 21, 2007 | 07:00 PM
racin jasin R's Avatar
Default over heating at WOT???
we put a new therostat in the car cause it was over heating!!!and this is the out come!!at idle the heat works and there is no over heating.when driving it at w.o.t for a breif second.the heat goes away and blows cold air, and it starts to over heat.any good ideas would help
thanks...
Old Feb 21, 2007 | 07:31 PM
Default Re: over heating at WOT??? (racin jasin R)
just seached.thanks
sorry
Old Feb 21, 2007 | 07:34 PM
adseguy's Avatar
I don't know if you have a d-series with stock head bolts, but they have a tendency to lift the head.
From what I'm seen, if you overheat after a WOT run the head is lifting. check your coolant and oil to see if they are mixing a little. If not the coolant may have black particles from the exhaust getting into the coolant.
Modified by adseguy at 10:56 PM 2/21/2007
Old Feb 21, 2007 | 08:34 PM
Default Re: over heating at WOT??? (adseguy)
thank you sir you got it right...thanks bro figured it out
Old Feb 21, 2007 | 08:36 PM
Joey Tribianni's Avatar
yep, replace headgasket and new head bolts
Old Feb 21, 2007 | 08:55 PM
Default Re: over heating at WOT??? (Joey Tribianni)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joey Tribianni &raquo;</TD></TR><TR><TD CLASS="quote">yep, replace headgasket and new head bolts</TD></TR></TABLE>
Old Feb 22, 2007 | 03:48 AM
batboyvaj's Avatar
just re-bleed
primerpimpin
Oct 23, 2009 06:49 PM
JDMlyfestyle
14
Nov 13, 2004 12:46 PM
CM-R
Apr 10, 2003 09:48 PM
legendboy
Mar 18, 2003 06:37 AM
GraphiteAccord
Nov 30, 2002 02:59 PM
