how much hp can i get from topmount manifold?
i have gsr 660hp@8000rpm with 25psi. my setup is JE 9:1 with 83mm, turbo T04R A/R 84 with Revhard Equal Length turbo manifold. if i want to change my manifold to top mount, any diffrent in hp or Tq?? thanks
Re: how much hp can i get from topmount manifold? (boostincoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrt »</TD></TR><TR><TD CLASS="quote">i have gsr 660hp@8000rpm with 25psi. my setup is JE 9:1 with 83mm, turbo T04R A/R 84 with Revhard Equal Length turbo manifold. if i want to change my manifold to top mount, any diffrent in hp or Tq?? thanks</TD></TR></TABLE>
does revhard make an equal length manifold?
Re: (hitatree.at125mph)
Yes! revhard made it. i stopped rev at 8000 rpm because exhaust gasket was leak.
any different!! Hp, Tq or spool time. thanks again
Man U FTW
an increase in efficiency will always yield an increase in power.....upgrading to a better flowing manifold will help....there are other things you could do too....ceramic coatings being one of those options
