1480bhp@ 20 psi and still going
We dynoed the motor for the Buick G/N last night and it made 1480hp @ 20 psi. This motor has a bit more hp in it since we got to the 1480hp number with no intercooler. We are putting a new set of heads on the engine today and will be re-dynoing with the intercooler on it this time. We are looking for around 1700hp@20-25 psi.
Here are the pics of the engine on the dyno and our dyno facility.
Modified by turbodano at 11:00 AM 2/20/2007
Re: 1480bhp@ 20 psi and still going (ZeremiaH)
I will have video today or tomorrow when the beast gets back up and running. I will tell you it;s f-@#! awsome when it comes up on boost. It sounds like it is going to rip the dyno off the floor.
We also have a larger a/r turbine housing on the way. The back pressure was getting a bit high on the exhaust side.
Re: 1480bhp@ 20 psi and still going (turbodano)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbodano »</TD></TR><TR><TD CLASS="quote"> I will tell you it;s f-@#! awsome when it comes up on boost. It sounds like it is going to rip the dyno off the floor. </TD></TR></TABLE>
I bet. I know I've seen small-child eating turbos before......but....one of them on steroids? Lol
Re: (AWDstylez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AWDstylez »</TD></TR><TR><TD CLASS="quote">Wish the dyno's I went to recorded all that data.
Nice job on the car. Pics? Or video would be even better?
What size/kind of turbo are you running?</TD></TR></TABLE>
Thnaks and the turbo is a 95mm S510.
Re: 1480bhp@ 20 psi and still going (boostedcivicsir)
This is a little bit different set up than the norm. Ken put a 477ci V8 in it.
I know it hurts me too but atleast I got him to take the blower off the car and go with the turbo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Alfa Turbo »</TD></TR><TR><TD CLASS="quote">Where was Backpress 1 measured? I assume it was pre turbine.
I like the craftsmanship in the work.</TD></TR></TABLE>
We measured the back pressure right at the turbine inlet. You can see the sensor in the pic of the motor on the engine dyno.
Re: (Dunc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dunc »</TD></TR><TR><TD CLASS="quote">My mouth dropped as soon as I saw the hp&tq at the lowest rpm of 4700. </TD></TR></TABLE>
The carb is from CSU they make great carbs for boosted apps.
The tq is funny a basic flat line you might say. 4700-7000 its almost straight across.
Can you say traction problem I knew you could.
Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 »</TD></TR><TR><TD CLASS="quote">what kind of intake temps was it seeing non intercooled??</TD></TR></TABLE>
We didn't check the inlet temps on this setup. On the last set up like this we had temps in the mid 200 degrees.
Re: (urbansi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbansi »</TD></TR><TR><TD CLASS="quote">Nice shop!</TD></TR></TABLE>
For real. You guys looking for an engineer?
