Clocking Carrier On Turbo?
Old Mar 29, 2007 | 02:01 PM
LSEGHATCH's Avatar
Default Clocking Carrier On Turbo?
Is there any way I can clock or rotate the carrier on a turbo? The 4th flange bolt is impossible to get out with the drain flange in the way and I can't access those bolts either. I need to bring the drain up top where the feed should be.
Old Mar 29, 2007 | 02:26 PM
agrn93ls's Avatar
Default Re: Clocking Carrier On Turbo? (LSEGHATCH)
not exactly sure what you mean but if you wanna rotate the "CHRA" (center section containing the bearings) then loosen the bolts that tighten it to the exh. housing. and then it will turn if your lucky but its most likely rusted together and will be a real pain.
Old Mar 29, 2007 | 05:13 PM
LSEGHATCH's Avatar
Default Re: Clocking Carrier On Turbo? (agrn93ls)
It's a newer turbo so it should work :crossed fingers:. I dont' know how else to get it off the manifold then.
D15Bbigred
May 18, 2007 03:03 PM
boonacka
Jul 6, 2005 12:44 PM
Nonsteezy
Oct 14, 2004 12:01 PM
sporkcrx
Oct 19, 2003 10:28 PM
paulzy
Oct 30, 2001 05:42 PM
