oil pressure problem
Old Mar 27, 2007 | 09:43 AM
2redstars's Avatar
Default oil pressure problem
going home on my lunch break today and i had a clear road ahead of me so i got on it mid 3rd gear and hit fourth for a couple seconds, then when i slowed down i noticed my oil pressure gauge(autometer elect.) read really low. so i pulled off the road, popped the hood, no excessive blowby, no smoke anywhere, oil is at normal level. started it back up, no noises or anything unusual. but the gauge reads 0, at idle, and jumps when i hit the gas. so i decide to turn around and go back to work, oil pressure reads about 40 (normally 75) when driving but immediatly drops when off the gas/out of gear. got back to work fine, no clanking, but there is a slight noise comeing from around the oil pump area. its really faint, but its defenitly a new sound. could the pump gears be broke?
Old Mar 27, 2007 | 09:44 AM
2redstars's Avatar
b18c1 block, gsr oil pump, rs sleeves....
Old Mar 27, 2007 | 12:27 PM
2redstars's Avatar
i was hoping to have some insight before the work day was over....
Old Mar 27, 2007 | 01:07 PM
Flamenco-T's Avatar
Default Re: (2redstars)
take off your turbo oil feed line from the turbo. Undo the distributor plugs and have somebody crank up the motor while you hold the oil feed line to see if any oil comes out of the oil feed line.
Also, check your oil from the oil pan to see if there's any metal shavings
stan
Old Mar 27, 2007 | 02:07 PM
2redstars's Avatar
thanks stan. i did this as soon as i got off work. pulled the oil feed off the turbo, set it aside, cranked it over and oil shot a good 6 ft. hooked it back up and started the car, oil pressure gauge read a solid 25, then started to flicker all over the place. going to get a new gauge, easy fix!
Old Mar 27, 2007 | 06:02 PM
t-powersi's Avatar
WELL I WAS MAKING A PASS ON THE TRACK WHERE I LIVE AND MY AUTOMETER GAUGE DID THE SAME THING TO ME AND THEN LATER JUST DIED DUE TO WEAK SENDING UNIT. GOT RID OF THAT PIECE OF **** AND GOT A DEFI AND NEVER HAD A PROBLEM SINCE. THOSE AUTOMETER GAUGES ARE SCARY
Old Mar 27, 2007 | 06:28 PM
Topdawgg's Avatar
sometimes the connections can be loose and the sender can not be givin the right level...
Old Apr 7, 2007 | 12:32 PM
2redstars's Avatar
so i went to autozone, bought a new gauge and just swapped the sending units. gauge worked fine for 1 day. and now its not getting a reading again. this time it didnt act funny at all, just stopped.
what makes the sending unit go bad?
Old Apr 8, 2007 | 07:35 AM
t-powersi's Avatar
autometer or cheap gauges sending units really suck they are really cheaply made from i switched over to my defi gauges neva had a problem
Cantcatchme
Dec 1, 2011 10:04 AM
silverwrench
Nov 4, 2010 12:45 PM
xlasianizelx
Aug 10, 2010 02:28 PM
IntegraMastaz
Jun 13, 2006 07:21 AM
dAng! Kris
Jan 24, 2005 12:38 PM
