yah another oil pressure ?
Old Mar 27, 2007 | 06:29 PM
THEDirtyDseriesWOOT's Avatar
Default yah another oil pressure ?
i have about 400 miles on the new build
d16z6 with a toga hv oil pump
at startup i have pretty hihg oil pressure.. once the car warms up 190-200ish
it gets low..
at idle its like 10-15 give or take
and at wot 65-70
when its starting to warm up i have 80psi all day long but once i get to 180 deg it just gets low..
is this cause maybe my bearing clearences are big?? or what im running 10W30 cheap **** to break it in.. tuning this sat gonna put some Amsoil in it what weight shoudl i run to help my pressure>? and is my pressure ok?
Old Mar 27, 2007 | 06:57 PM
Topdawgg's Avatar
those Idle and WOT numbers are normal...
Old Mar 27, 2007 | 08:01 PM
cool well what wieght do yall recomend running in Amsoil oil
Old Mar 27, 2007 | 09:55 PM
dunkd's Avatar
10-15 at idle is low in my opinion.
Old Mar 28, 2007 | 04:55 AM
stinker504's Avatar
When I was running 10-W30 I would idle at 10-15psi. Swapped to 10-W40 and got it up to a steady 20psi. It idled much better too.
Old Mar 28, 2007 | 06:30 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (stinker504)
i know it isnt a gm, but the general says 10psi for every 1000 rpms, so idle at 750, 7psi is considered normal. are you running race bearings? where the clearances? thou? thou and a half? 2thou? the looser the lower.
Old Mar 28, 2007 | 01:50 PM
yash im running race bearings.. but i dont know the clearance ill have to ask the machine shop whom built the short block
Old Mar 29, 2007 | 07:45 PM
noones replied i wanna run amsoil oil what wieght should i run
Old Mar 29, 2007 | 07:54 PM
highrev1987's Avatar
Default Re: (THEDirtyDseriesWOOT)
i am going to slightly TJ this topic but i a have almost the same issue mine is lower though, bump for oil weight question
i thought it was my oil pump?? strange...
Old Mar 29, 2007 | 08:07 PM
95GSRTT
Guest
Posts: n/a
It depends on how hot it gets there in the summer. You will want a thicker oil if it gets hot and a thinner oil when its cold outside. You could go with a 10w-40 or a 20-50. If you go with the heavier oil and it gets cold outside make sure you let the car run and idle for a while before you go smash on it....
Old Mar 29, 2007 | 08:15 PM
Default Re: (95GSRTT)
it is pulling this psi at 40 F
Old Mar 29, 2007 | 08:19 PM
95GSRTT
Guest
Posts: n/a
Default Re: (highrev1987)
Ya I was talking more about the OP. Your probably sounds like it might be a little bit more serious if its much lower. Not leaking any oil anywhere? Is everything stock or lsv?
Old Mar 29, 2007 | 08:29 PM
its a boosted d16z6 no leaks no smoke...
sorry again for the thread jack
Old Mar 29, 2007 | 08:37 PM
95GSRTT
Guest
Posts: n/a
Low on oil at all? If not, yes I would definitely check out your oil pump, What gauge are you using to check the oil pressure? Possible its off?
Old Mar 29, 2007 | 08:45 PM
autotmeter mechanical, oil pressure is perfect, i do feel a slight pulse in my clutch pedal ( i know thats strange) could it be a HG
Old Mar 29, 2007 | 08:58 PM
95GSRTT
Guest
Posts: n/a
If it was a headgasket I would think you would be seeing smoke or a leak, so I highly doubt thats it. Eh just take out the gauge so you never have to think about it
Old Mar 29, 2007 | 09:23 PM
autometer guage here also.. yah im thinkgin of goin 20w50 it gets hot as expletive here.. louisiana
Old Mar 29, 2007 | 10:08 PM
yeah that would work for high heat, i am near philly its icy here, its good for Intake Temps
sikpupy
Oct 13, 2018 07:03 PM
sik_tC
Dec 20, 2008 01:20 PM
AsSanitySlipsAway
12
Aug 27, 2006 09:55 AM
AsSanitySlipsAway
12
Aug 18, 2006 06:29 PM
PA MATT
Apr 8, 2006 12:20 PM
