aem wideband
http://i94.photobucket.com/alb...9.jpg
http://i94.photobucket.com/alb...8.jpg
http://i94.photobucket.com/alb...7.jpg
http://i94.photobucket.com/alb...5.jpg
i was wonder if it was possible to cut off the plug on the sensor one since i baught a new sensor and sauder them together
if you have the connector that goes into the back of the gauge, then yes, you can hack the connector off. I did, the damn connector is so big it wouldnt go through the firewall, so we cut it off and put a spade connector on each wire then heat shrinked it together.... much smaller, which went through the firewall grommet without having to make a new hole. Just match color to color on each side
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boilermaker1 »</TD></TR><TR><TD CLASS="quote">if you have the connector that goes into the back of the gauge, then yes, you can hack the connector off. I did, the damn connector is so big it wouldnt go through the firewall, so we cut it off and put a spade connector on each wire then heat shrinked it together.... much smaller, which went through the firewall grommet without having to make a new hole. Just match color to color on each side</TD></TR></TABLE>
PM YOU BRO
PM YOU BRO
JohnnyLawless1
Nov 21, 2013 04:42 PM
