Need d16z6 build help
Old Mar 25, 2007 | 11:47 PM
TehMoonRulz's Avatar
Default Need d16z6 build help
I'm doing a budget EF swap and aiming for 190-200 whp
My plans include:
Act Heavy Duty Clutch (Can't decide between 8 or 11 lb flywheel yet)
ZC transmission
Srt-4 or starion intercooler
dsm injectors/bov
hf manifold
all piping ( to/from intercooler and exhaust) will be custom fabbed by my uncle who owns a welding shop
I just can't decide on a turbo (or waste gate if needed, but I'll look into that) to meet my goals without breaking the bank too much. I'm trying to stay under $2000 and keep stock internals. Your input is appreciated
Old Mar 26, 2007 | 07:43 AM
HiProfile's Avatar
Default Re: Need d16z6 build help (TehMoonRulz)
Well the budget doesn't lend itself to a BB turbo like a GT28R all that much, so I'd suggest something like a 50trim T3 with a stg1/.48 AR exhaust. Fast spool and 200+ whp with moderate boost levels will make it fun to drive, and inexpensive. I would suggest the heavier FW, as the fast spooling turbo for your 200whp goal will more than make up for the lack of any lowend or lag.
You could have a machine shop mill the HF mani to accept a tial WG, as it has enough meat above the o2 sensor hole to flatten it out and bolt one up. The other option is to use a t3 internal wg, but you'd have to swing the turbo out from the block with a 2" 45 degree pipe elbow. The wg actuator wouldn't fit otherwise. I did this and fit a larger t3/t04b in there with the HF, internal gate w/3" dp - and AC.
Old Mar 26, 2007 | 11:07 AM
Default Re: Need d16z6 build help (HiProfile)
I'm taking AC out if that matters
What kinda psi are we talking about with that t3?
Old Mar 27, 2007 | 10:09 AM
Only bump Looking forward to a HMT set-up
ted
Jan 1, 2005 09:26 PM
1badda
Nov 22, 2004 08:55 AM
a2sportcompacts
Jul 17, 2004 11:02 PM
