manuel boost controllers vs electronic boost controllers
Old Mar 27, 2007 | 09:23 AM
boosted_ejcivic's Avatar
Default manuel boost controllers vs electronic boost controllers
which one is better in the sense that its more reliable and accurate then the other?
thanks
Old Mar 27, 2007 | 09:33 AM
EJ1 wilcox's Avatar
Default Re: manuel boost controllers vs electronic boost controllers (boosted_ejcivic)
Electronic is more accurate, manual is cheaper.
Old Mar 27, 2007 | 09:39 AM
jfruauff's Avatar
The higher the price the more reliable,lol. Well most of the time
Old Mar 27, 2007 | 01:45 PM
tegdude227's Avatar
way more functions with electric like gear based boost warning features scramble mode password protection just a few examples the only down side is cost
Old Mar 27, 2007 | 03:19 PM
awdgsx96's Avatar
Default Re: (tegdude227)
Manual can be equally as accurate as an electronic, and for alot cheaper. The Hallmann Pro is used by many with no problems and stable boost control
Old Mar 27, 2007 | 03:36 PM
trickeng's Avatar
An electronic boost controller will typically be much more accurate. There are cars we have built which spool quick and hit there set boost levels dead-on, but that has only been true for a few low boost cars.
With Hp climbing out of sight and traction not climbing fast at all, the benefits of an electronic boost controller which can adjust boost around many parameters is huge for low ET's or Street racing.
Old Mar 27, 2007 | 03:55 PM
PHDZINE's Avatar
Default Re: (trickeng)
Electronic boost controllers can keep the diaphram (Valve) closed longer before it hits desired boost before opening the valve...allowing for faster spool up unlike some manual boost controller that slowly open allowing you to loose some manifold pressure before hitting desired boost levels.
Old Mar 28, 2007 | 03:11 AM
aimre's Avatar
Default Re: (PHDZINE)
True, though most manual ones are gated now, so they wont creep open till a close to desired boost level is aquiered.
One good thing about elec ones its, Changing on the fly, and overboost protection
Integra21
May 21, 2006 04:16 PM
Integra21
May 21, 2006 04:15 PM
alpha
Sep 26, 2005 09:09 AM
B16Civic93
Feb 20, 2005 06:28 PM
boostincoupe
Jul 4, 2003 04:07 AM
