Coolant lines for turbo
Old Mar 25, 2007 | 04:54 PM
jfruauff's Avatar
Default Coolant lines for turbo
I just bought a new garrett turbo that has oil and coolant fittings. I was wondering where you guys tap to into to feed the coolant and where you tap for the return???
Thanks
Old Mar 25, 2007 | 05:29 PM
boost4life's Avatar
u can buy an oil block adapter that goes between ur block and oil filther also the adapter has extra holes for iol pressure temp even ls vtec greddy, golden eagle, m factory make them just search m factory on ht the best price i saw was 39 bucks
Old Mar 25, 2007 | 05:32 PM
BodyKits NW's Avatar
Default Re: Coolant lines for turbo (jfruauff)
I use a pair of -6 stainless steel lines, and have a bung welded on the bottom of my radiator tank as my feed. Then for the drain I used the nipple that's used for letting out air bubbles from the coolant system. I removed the fitting and tapped it so I could attach my -6 line there.
I have extra lines that I am selling too. I made a thread in the FI forum.
Old Mar 26, 2007 | 09:06 AM
jfruauff's Avatar
Default Re: Coolant lines for turbo (BodyKits NW)
Any other ways without welding ****
Old Mar 26, 2007 | 09:26 AM
sharkytm's Avatar
Throttle body lines is where I've always seen it done from.
Old Mar 29, 2007 | 08:16 AM
jfruauff's Avatar
Default Re: Coolant lines for turbo (sharkytm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sharkytm &raquo;</TD></TR><TR><TD CLASS="quote">Throttle body lines is where I've always seen it done from.</TD></TR></TABLE>
Can someone be a lil more specific.
Old Mar 29, 2007 | 08:20 AM
PrecisionH23a's Avatar
Throttle body and bottom of radiator. You can actually get an adapter fitting so you can use the drain plug.
Old Mar 29, 2007 | 10:43 AM
White Smoke's Avatar
i my honda
Global Mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jfruauff &raquo;</TD></TR><TR><TD CLASS="quote">Can someone be a lil more specific.</TD></TR></TABLE>
Dude, search. This exact thread comes up at least twice a month.
Old Mar 30, 2007 | 12:50 PM
ludeDVR's Avatar
Default Re: Coolant lines for turbo (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">You can actually get an adapter fitting so you can use the drain plug.</TD></TR></TABLE>
Where do you get something like that at?
Old Mar 30, 2007 | 09:28 PM
Sprockets's Avatar
Default Re: Coolant lines for turbo (ludeDVR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludeDVR &raquo;</TD></TR><TR><TD CLASS="quote">Where do you get something like that at?</TD></TR></TABLE>
It should be 1/4" NPT. At least my piece of **** C&R is.
Old Mar 31, 2007 | 07:00 AM
eggie75's Avatar
take the coolant line from the throttle body run it to the turbo - run another line from the turbo to the intake manifold.
powerdbygarrett
Mar 13, 2009 10:53 AM
hondapimpin420
May 17, 2007 09:41 AM
