Motorola 3 Bar MAP Sensor Install
Old Mar 27, 2007 | 12:32 PM
Astig's Avatar
Default Motorola 3 Bar MAP Sensor Install
What I did was use an extra TPS Sensor housing since it uses the same plug as the MAP. I gutted the inside, soldered the wires to each prong, and filled the rest with 5 Minute Epoxy. (By the way, soldering the MAP sensor was the biggest pain in my *** ever! I guess having a jeweler's soldering iron would have been easier)
I plan to mount this to the firewall and run a vacuum line. I'm using a Victor X manifold, I think it has extra ports in the back there. Will that be fine for a vacuum source? I'll also leave the stock MAP in place, just not plugged in.
Hope this works out, I know the wiring schematic is correct. Just wanted to show everyone the install.
Old Mar 27, 2007 | 03:33 PM
B18Flip's Avatar
Default Re: Motorola 3 Bar MAP Sensor Install (Astig)
good idea lol
Old Mar 27, 2007 | 03:57 PM
Astig's Avatar
Default Re: Motorola 3 Bar MAP Sensor Install (B18Flip)
It may not be pretty, but I'm okay with it.
GM 3 Bar would have been an easier install, but a little more costly.
Old Mar 27, 2007 | 06:51 PM
HamiltonRex's Avatar
yes you can use any vac port on the bottom of your manifold.
Old Mar 27, 2007 | 06:55 PM
Topdawgg's Avatar
cool idea
i had a motorola 2.5 bar go all to **** from bad pins.. all because it was exposed
SpoolnByYou
Dec 29, 2005 10:00 AM
CiViC SiR
Oct 20, 2003 11:00 AM
1.8T_EG
May 12, 2003 09:58 PM
BLKCRX
Mar 26, 2002 01:41 PM
austrian type-R
Sep 1, 2001 05:16 PM
