Another Injector Question :(
Old Mar 25, 2007 | 03:32 PM
vietxdragon's Avatar
Default Another Injector Question :(
hey guys i know this may sound like another retarded question but im really confused on the h22 injectors fitting into a obd1 gsr. I ohm tested my gsr injectors and they read aroud 12 ish or w.e and the h22 injectors i have read around 2.5+ ohms. Now i posted and searched up that the h22 injectors are saturated and 290cc? correct me if i am wrong honda guru's. I thought OBD1 gsr's were saturated as well. but the ohm readings on my gsr injectors and 12ish. i may be mixed up but plz help me out..... This is for a JRSC'd gsr thats OBD1
thanks!
Old Mar 25, 2007 | 03:38 PM
dpetro1's Avatar
Default Re: Another Injector Question :( (vietxdragon)
h22 injectors are peak and hold, not saturated so the readings you got are perfectly correct. and im not so sure that 290cc injectors are big enough for a jrsc, are you using an fmu?
Old Mar 25, 2007 | 03:41 PM
unfortunately yeah im still using the FMU, so the h22 injectors i have are peak and hold the 290cc's? CRAP now would the obd2 h22 injectors that are 345cc work , plug and play on car motor?
Old Mar 25, 2007 | 03:45 PM
dpetro1's Avatar
Default Re: (vietxdragon)
i was under the impression that all h22 injectros were p&h. but maybe someone else can chime in.
Old Mar 25, 2007 | 04:08 PM
soon2b_EG's Avatar
92-95/96 P&h 345cc
97-01 Sat 290cc
I think this is correct.
Old Mar 25, 2007 | 04:37 PM
dpetro1's Avatar
Default Re: (soon2b_EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soon2b_EG &raquo;</TD></TR><TR><TD CLASS="quote">92-95/96 P&h 345cc
97-01 Sat 290cc
I think this is correct.</TD></TR></TABLE>
after a quick search it looks like you are correct.
Old Mar 25, 2007 | 05:32 PM
so does it matter then if i run these injectors in my gsr?? the ohm readings are different, my injectors in the car are reading high ohms. which would make it peak and hold right?? or does it not matter than becuz the h22's are low ohms&gt;&gt; frustrated xD
Old Mar 25, 2007 | 06:35 PM
95dc2teg's Avatar
if your going to run the h22 injectors which are peak and hold u need a resistor box.
Old Apr 4, 2007 | 10:34 AM
civic401's Avatar
New User
Sorry guys, is the 290cc injectors off the no-vtec or vtec prelude?
Old Apr 4, 2007 | 10:47 AM
PrecisionH23a's Avatar
97-01 Sat 290cc
Correct. All 97-01 prelude's are vtec. The 92-95 non-vtec's are 240cc.
vietxdragon
Mar 25, 2007 05:43 PM
crazyslowhatch
Sep 27, 2004 03:40 PM
joshonater
Jul 29, 2004 07:57 PM
AndyD
Oct 3, 2003 11:30 PM
