500+whp Possible?
Old Mar 28, 2007 | 08:34 PM
Fate's Avatar
Default 500+whp Possible?
I've been looking at all these wonderful setups and I'm thinking to myself, maybe I should sell myself short @ 400whp. I'm wondering if a fully built 2.0L B18B with say a SC61 is capable of 500whp w/o nitrous. NON-VTEC of course and must be able to run on pump gas.
If its possible I'm thinking of tryin for 500whp w/out nitrous and say 550whp with it(Just a small 50 or 75 shot).
Old Mar 28, 2007 | 08:48 PM
TIGboy's Avatar
Default Re: 500+whp Possible? (EGRacersInc)
describe your setup... fully built meaning sleeves, cams etc..??
Old Mar 28, 2007 | 10:20 PM
zexxbo's Avatar
Default Re: 500+whp Possible? (TIGboy)
you wouldnt want to run pump gas with 500whp and youd need a bb turbo to have a decent powerband.
Old Mar 28, 2007 | 10:31 PM
rhamlinii's Avatar
With an intake manifold, cams, and valvetrain you will be able to make 500whp on a sc61. Providing, your bottum end will take. With methnal/ water injection you'll be able to do it on pump gas aswell.
Old Mar 29, 2007 | 08:07 AM
Fate's Avatar
Welll the setup I'll be running is as follows:
B18B sleeved and bored to 2.0L
Worked LS Crank(Stewart Racing Engines)
ARB Bolts Throughtout Whole Engine
ACL or Honda Bearings Thoughout
RS Machine Rods and Turbo Pistons
Worked LS Head w/ Crower 404s, Crower Springs/Retainers, and Ferrea Plus Size Valves
AIR or AEBS Intake Manifold
70mm TB
I figured that setup would get me there. Well if 500whp isn't achievable on pump gas with methanal/water injection should I just stick with 400-450whp?
Old Mar 29, 2007 | 08:19 AM
PrecisionH23a's Avatar
B20 SC61 (t3 .63 a/r)
Old Mar 29, 2007 | 08:20 AM
JoePSI's Avatar
Default Re: (EGRacersInc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">
B20 SC61 (t3 .63 a/r)</TD></TR></TABLE>
exactly what I was going to say.
F' running meth/alky. Just run race gas and up the boost. 500whp will be easy for that setup.
Old Mar 29, 2007 | 10:38 AM
White Smoke's Avatar
i my honda
Global Mod
Why do you want to run n2o? You can definitely make 500HP with an SC-61. I would not push higher then 450 on pump, why risk it??? You can't use that power on the street.
Old Mar 29, 2007 | 10:53 AM
melovesboost's Avatar
You got E85 in your Area?
Old Mar 29, 2007 | 02:34 PM
Schister66's Avatar
Man U FTW
Default Re: 500+whp Possible? (zeimbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zeimbo &raquo;</TD></TR><TR><TD CLASS="quote"> youd need a bb turbo to have a decent powerband.
not necessarily true...plenty of guys run the SC61 on their setups and make great poewr with them....not to mention having a great powerband. Also since he's at a 2.0L,he will spool that SC61 sooner than a stock bore obviously...
Old Mar 29, 2007 | 03:10 PM
zexxbo's Avatar
Default Re: 500+whp Possible? (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">not necessarily true...plenty of guys run the SC61 on their setups and make great poewr with them....not to mention having a great powerband. Also since he's at a 2.0L,he will spool that SC61 sooner than a stock bore obviously...</TD></TR></TABLE>
eh, i guess its just personal preference. as seen in the dyno graph, he would only have about 2300rpms of boost on an sc61..
Old Mar 29, 2007 | 03:47 PM
boosted92's Avatar
eh, i guess its just personal preference. as seen in the dyno graph, he would only have about 2300rpms of boost on an sc61.. </TD></TR></TABLE>
That dyno shuts off at 7300. An LS-headded motor with decent cams will hold power to 8000+ no problems.
Not to mention ball bearings don't do that much to speed up spoolup, they mainly help with transient response.
Old Mar 29, 2007 | 04:21 PM
Schister66's Avatar
Man U FTW
Default Re: 500+whp Possible? (boosted92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted92 &raquo;</TD></TR><TR><TD CLASS="quote">
Not to mention ball bearings don't do that much to speed up spoolup, they mainly help with transient response.</TD></TR></TABLE>
someone who knows something intelligent for a change. I'm so glad that people actually know why ball bearing turbos are used....its not all bandwagon
Old Mar 29, 2007 | 05:09 PM
Fate's Avatar
Well it looks like I may just shoot for 450whp on pump and up it to around 500-550 with race gas.
The reason for the nitrous is because I like the little extra umph it gives you. I'm still undecided if I'm even going to put it on.
So 450whp on pump sounds fun. Thanks for the help guys.
Old Mar 29, 2007 | 05:11 PM
SwappedTURBOegg's Avatar
Default Re: (melovesboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by melovesboost &raquo;</TD></TR><TR><TD CLASS="quote">You got E85 in your Area?</TD></TR></TABLE> this mans got the idea
Old Mar 29, 2007 | 05:20 PM
Fate's Avatar
Not that I know of. Just Turbo Blue(110), Premium(93), and some Air Craft Fuel(180 maybe?).
Old Mar 29, 2007 | 05:27 PM
zexxbo's Avatar
b20 head/ls head- same thing. i doubt that dyno was running a stock head with that setup. a ball bearing turbo would start spooling prolly 600rpms or so sooner. and either way, you act like he wouldnt be better off with a bb turbo.. btw, im actually running a journal bearing turbo myself.
spoon93
Jun 22, 2011 01:41 PM
hondapimp125
Jan 22, 2010 06:59 PM
quikcivic
Mar 7, 2006 06:58 PM
MaxBoost
37
Mar 11, 2004 07:15 AM
