Couple of LS turbo questions...
Do i need to get a fpr? or is it not necessary? im only gonna be running 12-14psi and ive got a high flow fuel rail and 440cc injectors.
Where can i find a filter for the breather tube on the head?
Do i need an aftermarket fuel pump?
Re: Couple of LS turbo questions... (Blacklabel182)
I had a boosted LS on 14psi and yes i recommend a FPR. simply bumpin the fuel pressure can help with tuning. and if you plan on doing more youll have one less thing to buy
Re: (93turbo16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 »</TD></TR><TR><TD CLASS="quote">Definitley get a fuel pump a walbro 255 is a good choice and you should be fine with just the pump, injectors and stock fuel pressure.</TD></TR></TABLE> yup its too cheap u got to get it.
Re: (93turbo16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 »</TD></TR><TR><TD CLASS="quote">Definitley get a fuel pump a walbro 255 is a good choice and you should be fine with just the pump, injectors and stock fuel pressure.</TD></TR></TABLE>rgr that
Re: (SwappedTURBOegg)
what do the stock fuel pump and fpr top out at? will it make a difference at all?
and where do i find small filters for the breather hole on the header?
Initial_drift
02-02-2007 03:49 PM
JDM turbo DC
11-08-2005 05:51 PM
RTW DC2R
09-27-2005 01:46 PM
