Quick initial startup questions regarding injectors.
Old Mar 25, 2007 | 08:24 AM
slooogsr's Avatar
Default Quick initial startup questions regarding injectors.
On a fresh build using the stock computer during initial startup, is it okay to use 780cc injectors or should i use the stock ones for it? I wasnt sure if the computer itself and the stock fuel pressure reg would be enough to keep the amount of fuel at stock levels during idle........ thanx guys
Old Mar 25, 2007 | 09:53 AM
2redstars's Avatar
use the stock injectors. the 780's will flood your cylinders, possibly causing damage from washing oil away
Old Mar 25, 2007 | 01:16 PM
slooogsr's Avatar
Default Re: (2redstars)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2redstars &raquo;</TD></TR><TR><TD CLASS="quote">use the stock injectors. the 780's will flood your cylinders, possibly causing damage from washing oil away</TD></TR></TABLE>
I was aware of fuel wash, but i didnt know if this would happen during idle.......... any other opinions?
Old Mar 25, 2007 | 04:04 PM
dpetro1's Avatar
Default Re: (slooogsr)
i highly doubt your stock ecu will even start up 780cc injectors. they are more than 3 times bigger than stock. you need to get a basemap before you start the motor. and i would suggest tuning immediately upon startup.
Old Mar 25, 2007 | 05:49 PM
akira712's Avatar
dont run the stock ecu with 780's
use stock injectors.
Think about the injector duration for idle its going to be, lets say, 10ms for 780's and 30ms for 240's
Old Mar 25, 2007 | 06:43 PM
slooogsr's Avatar
Default Re: (dpetro1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpetro1 &raquo;</TD></TR><TR><TD CLASS="quote">i highly doubt your stock ecu will even start up 780cc injectors. they are more than 3 times bigger than stock. you need to get a basemap before you start the motor. and i would suggest tuning immediately upon startup. </TD></TR></TABLE>
I definitely understand. I was just making sure. It will be tuned by Jeff Evans using Neptune after the initial startup. I plan on installing an injector driver for the 780's and wanted to install before i put the motor in. I cannot do that since the stock injectors arent peak and hold.
I will definitely fire it up initially with the stocks, thanx fellas.
allnaturalb16
Oct 16, 2006 01:51 PM
1SickHb
Dec 9, 2005 08:13 AM
BLK99VTECR
Oct 18, 2004 11:24 AM
