Turbo Manifold- cant not enough space to put on all the nuts...
Guest
Posts: n/a
Just as the title says, there isnt enough room to put the nuts onto the studs for my turbo manifold to bolt onto the head. Im using a really thick gasket, anyone think it would be alright to skip out on one of them?
Re: Turbo Manifold- cant not enough space to put on all the nuts... (vestalfootball72)
u have to have them all loose so u can pul the manifold out and go in AS ur tightting the tight ones, or ur beat and bought a **** mani
Guest
Posts: n/a
Re: Turbo Manifold- cant not enough space to put on all the nuts... (93supercoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93supercoupe »</TD></TR><TR><TD CLASS="quote">u have to have them all loose so u can pul the manifold out and go in AS ur tightting the tight ones, or ur beat and bought a **** mani </TD></TR></TABLE>
gonna try that... good idea!
Re: (92redhatch)
or you can use longer studs, I had to do that cause my first manifold had a super thick head flange and very little clearance for bolts.
Re: (katoeh2o)
Right! You have to just barely put the manifold on and then as the manifold goes on tighten the hard to get to nuts. Im guessing you have ram horn and your trying to get the nuts on the sides?
Guest
Posts: n/a
Re: (1Bar GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1Bar GSR »</TD></TR><TR><TD CLASS="quote">
Right! You have to just barely put the manifold on and then as the manifold goes on tighten the hard to get to nuts. Im guessing you have ram horn and your trying to get the nuts on the sides?</TD></TR></TABLE>
got it- just had to do the two ones that i coudlnt get first, then push the manifold in and do the rest- Im using M8 1.25 pitch 20mm long SS grade 8.8 bolts for a few of them- they work great!
BongoBennie
Engine Machining & Assembly
01-29-2017 07:50 PM
