MAP sensor pinout question
Old Mar 23, 2007 | 07:17 PM
B18EG6's Avatar
Default MAP sensor pinout question
Hello-
I am adding a 2.5 bar motorola MAP sensor, and had a question about the wire colors. It is an OBD1 GSR harness I believe.
I was reading that the MAP had the following colors
White (Vout)
Grn/wht (ground)
Yel/red (+5v)
However, my MAP has these colors:
grn/wht
white
yel/wht
Is my yel/wht equivalent to the yel/red +5v?
Old Mar 24, 2007 | 06:55 AM
B18EG6's Avatar
Default Re: MAP sensor pinout question (B18EG6)
bump for saturday
Old Mar 24, 2007 | 07:15 AM
boostedcivicsir's Avatar
Mr. Badwrench
well green / white is ground, put the black test lead on ground, turn the key on, see what wire has the 5v reference. then the other that has no reading, should be the signal wire.
Old Mar 24, 2007 | 08:04 AM
B18EG6's Avatar
Default Re: MAP sensor pinout question (boostedcivicsir)
Thanks for the reply.
the motor isnt in the car so I can't test it like that Nor is the car going to be running for at least a month or so.
Old Mar 26, 2007 | 05:30 PM
B18EG6's Avatar
any more opinions?
Old Mar 26, 2007 | 06:06 PM
boosted k20's Avatar
u r correct
Old Mar 26, 2007 | 06:09 PM
B18EG6's Avatar
Default Re: MAP sensor pinout question (boosted k20)
awesome, thanks for the reply
Old Mar 26, 2007 | 08:04 PM
USDM 4G VTEC's Avatar
Old Mar 26, 2007 | 09:37 PM
GetawayInMoscow's Avatar
1 to white
2 to green/white
3 to yel/white
Old Mar 27, 2007 | 03:33 AM
B18EG6's Avatar
Default Re: MAP sensor pinout question (GetawayInMoscow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GetawayInMoscow &raquo;</TD></TR><TR><TD CLASS="quote">1 to white
2 to green/white
3 to yel/white</TD></TR></TABLE>
perfect, thanks.
What harnesses are the yel/red found on?
Old Mar 27, 2007 | 09:20 AM
I'm not sure. But you will know if you did it right because if you screwed something up your car will run like **** and also you will be able to pull the code from the ECU. If it's code 5 thats MAP sensor.
Old Mar 28, 2007 | 12:36 PM
teal_dx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18EG6 &raquo;</TD></TR><TR><TD CLASS="quote">perfect, thanks.
What harnesses are the yel/red found on?</TD></TR></TABLE>
civic eg harness have the yel/red
Rand The Man
20
Sep 18, 2013 05:32 AM
soulo
Feb 27, 2008 09:03 AM
I B BANGGIN
Feb 6, 2007 07:50 PM
ItsStockOfficer
Apr 8, 2005 08:27 PM
xXx Justin xXx
Jun 18, 2003 09:49 AM
