how to instal a missinglink
Old Mar 26, 2007 | 10:30 PM
civic_sc's Avatar
Default how to instal a missinglink
anybody can help me i still have a chek engine code (map sensor)
when boosting 7 psi using only the wastegate ...
i instal a missing link but the problem is still there...
where cose the vacum on the missing link and sould it have a chek valve on it ....
let me know thks
Old Mar 26, 2007 | 10:44 PM
96vtecI4's Avatar
most people will tell you not to install it and buy a standalone, sorry i cannot help i just thought i'd prepare you for what people will say lol.
Old Mar 26, 2007 | 10:47 PM
civic_sc's Avatar
i know but the custumer just want to run it like this .. at 7 psi....anybody else...
hes runnig t3t4 turbo on stock b18 ...
stock ecu
jrsc fmu
missinglink
should i install a vaccum rail...or some check valve ..cause on the b18 intake there is only 1 vaccum inlet...and now there is the fuel reg on it the fmu the bov and the wastegate....including cruise control....
thks for your help guys...
Old Mar 27, 2007 | 03:49 AM
JoePSI's Avatar
Default Re: (civic_sc)
The missing link is very easy to install, so i'm guessing you have it installed correctly. The missing Link is a check valve.
If the one you bought is not working Just goto ace hardware and get somethinkg like this...
https://honda-tech.com/zerothread?id=1921020
Just put a fitting on the top of the missing link with a vac line attached to it, then run that linke to a check valve and run the other end of that check valve to the map sensor. And if you are still throwing a CEL I would suggest getting a 3bar and a chipped ECU with chrome(cheap) and get it tuned. Its the smarter route anyway.
nexgen91
Dec 30, 2007 04:19 PM
CJJones87
Sep 25, 2005 10:28 AM
Fatty_1775
Oct 11, 2004 03:46 PM
yellow blur
May 21, 2002 09:52 AM
