Can I use this vacuum port?
I tell doctors what to do
The pcv port with the white vacuum cap on it. Can I use it for my boost guage or something? I'd rather not just have it capped off.
Re: Can I use this vacuum port? (boostedcivicsir)
I don't know what you mean by vent system. Do you just mean catch cans without a vacuum source? If so yes. Here https://honda-tech.com/zerothread?id=1917722
Mr. Badwrench
Re: Can I use this vacuum port? (ILcrxsi1)
just have the 2 hoses coming off of the block into tha tanks? there is no where for the pressure to go. this is just my oppinion from the pics, if i saw it in person i could make a better judgement.
but to answer your question, you can use the port as a source of manifold vacuum.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">just have the 2 hoses coming off of the block into tha tanks? there is no where for the pressure to go. this is just my oppinion from the pics, if i saw it in person i could make a better judgement.
but to answer your question, you can use the port as a source of manifold vacuum.</TD></TR></TABLE>Somebody else in that thread said the same thing about the pressure. I guess I just take bad pics because there is plenty of room to breath. One hone comes from the block the other come from the valve cover breather.
Thanks for answering the question though .
josh0407
05-05-2007 08:12 PM
