arp headstud/head gasket
Old Mar 25, 2007 | 04:00 PM
teddy_dc2's Avatar
Default arp headstud/head gasket
replaced my head gasket with oem one a few months back, we accidently put the h.g. on the wrong side and had to filp it around, i remember having to use an allen wrench to hand tighten the arp studs then 70-75 ft-lb on the 12mm nut that holds it down. i am leaking oil out the front of the engine and seem to have oil mixing in cylinders. does the stud have to be torqued before you put on the head and final nut on? could just be the head gasket was unproperly crushed?? (cause i want to replace it with a cometics one this time before i tune it.)
Old Mar 25, 2007 | 04:41 PM
A.E Motoring's Avatar
Default Re: arp headstud/head gasket (teddy_dc2)
replace the head gasket again
Old Mar 25, 2007 | 04:48 PM
teddy_dc2's Avatar
that's what i'm doing and wanted to know if the arp studs have to be pre torque before the nut is torqued?
Old Mar 25, 2007 | 08:03 PM
abnaasefmb's Avatar
Default Re: (teddy_dc2)
i remember earl saying, tq them to 4 ft/lbs thats what i did. then 25 / 40/ 65 with arp lube on the 1/2" nuts.
Old Mar 25, 2007 | 08:10 PM
bigbadboy's Avatar
i got a cometic hg and i have the same problem you are having now. i'm changing over to stock hg with copper spray
Old Mar 26, 2007 | 04:42 AM
PrecisionH23a's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teddy_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">replaced my head gasket with oem one a few months back, we accidently put the h.g. on the wrong side and had to filp it around, i remember having to use an allen wrench to hand tighten the arp studs then 70-75 ft-lb on the 12mm nut that holds it down. i am leaking oil out the front of the engine and seem to have oil mixing in cylinders. does the stud have to be torqued before you put on the head and final nut on? could just be the head gasket was unproperly crushed?? (cause i want to replace it with a cometics one this time before i tune it.) </TD></TR></TABLE>
Did you torque down the upside down headgasket? If so... that could be the problem. Also, did you torque the studs in a criss cross pattern?
Old Mar 26, 2007 | 06:36 AM
rmcdaniels's Avatar
I actually back my studs out half a turn before I tighten the nuts. Never had any oil problems (except that time I accidentally used a LS/VTEC gasket with a VTEC motor and shot 6 quarts of oil all over my driveway).
And the nut is a 1/2" 12-point, not a 12mm.
Old Mar 27, 2007 | 06:31 PM
teddy_dc2's Avatar
yes i did torque the upside down gasket but never really seen leaks till now. how many qts of oil you guys use? i'm using cheap 5qt 10w30 quaker state. yes i torqued them opposite way i took them out crisscross center out.
Old Mar 27, 2007 | 08:06 PM
abnaasefmb's Avatar
i once put mine on upside down, tq'ed it and noticed it before i fired up the engine. flipped it over, boosted on it for a while no problems. then one day i got some smoke and a cool new scoobie sound. i took it apart and it was the ringlands that let go. headgasket was fine.
metalmulisha87
Jun 29, 2010 10:43 AM
lsvtec_cp
Jul 1, 2009 06:22 AM
petrv
Apr 12, 2004 12:30 PM
rschoener
Aug 18, 2003 07:48 AM
