vtec stays on?
Old Mar 24, 2007 | 06:32 PM
hialeahzbg's Avatar
Default vtec stays on?
i have a 95 gsr with a jdm front and a stock gsr motor with a turbo kit. for some reason my vtec stays on after its been engaged. so it stays on all the time. so it will make the car bog out. what could it be? i need your help...
Old Mar 24, 2007 | 07:41 PM
leed's Avatar
Default Re: vtec stays on? (hialeahzbg)
Stock ECU?
If you are running a CROME map w/ no vtec pressure signal, it will do as you describe. Not mechanically, but it will stay on the high cam map until you cycle the ignition.
Have you verified w/ a test light on the solenoid?
Old Mar 24, 2007 | 08:51 PM
hialeahzbg's Avatar
its a chipped ecu...
yes i just got dyno tuned on crome pro..it did this before when i was tuned on a vafc...it while engage and stay on causing the car to bog out when its around 2k rpm...havent check the solenoid yet...what do i look for?
Old Mar 24, 2007 | 09:01 PM
mtber's Avatar
Default Re: (hialeahzbg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hialeahzbg &raquo;</TD></TR><TR><TD CLASS="quote">its a chipped ecu...
yes i just got dyno tuned on crome pro..it did this before when i was tuned on a vafc...it while engage and stay on causing the car to bog out when its around 2k rpm...havent check the solenoid yet...what do i look for?</TD></TR></TABLE>
Contact your tuner as he should have already noticed this as being an issue while tuning the car & or should have known it was an issue with crome.
As described above, disabiling the vtec oil pressure switch causes the issue you are having on crome pro.
Old Mar 24, 2007 | 09:07 PM
hialeahzbg's Avatar
yea he told me about it...i already knew about it also but i thought it was the vafc doing it.. he said it might be the wiring...
Old Mar 25, 2007 | 05:09 AM
morgan@synapse motorsport's Avatar
do you have the vafc and the crome hooked up at the same time?
Old Mar 25, 2007 | 09:41 AM
boosted k20's Avatar
Default Re: (mike@synapse motorsport)
connect the Vtec pressure switch signal wire and the vtec wire (pin D6 and Pin A4) together. this will solve the problem
Old Mar 25, 2007 | 07:55 PM
hialeahzbg's Avatar
do u got any pics of these pins? ima noob...
naw the vafc was taken off when i got it dyno tuned...
Old Mar 25, 2007 | 08:09 PM
CivicVX94's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hialeahzbg &raquo;</TD></TR><TR><TD CLASS="quote">i have a 95 gsr with a jdm front and a stock gsr motor with a turbo kit. for some reason my vtec stays on after its been engaged. so it stays on all the time. so it will make the car bog out. what could it be? i need your help...</TD></TR></TABLE>
I'd have to say it's the jdm front that's the source of your issues. It's annoyed that the rest of the car isn't jdm too...Ironically, I had the same problem. cross breeding ftl
Sorry, I couldn't resist
Old Mar 25, 2007 | 11:10 PM
mtber's Avatar
Default Re: vtec stays on? (CivicVX94)
Your tuner should not have let you leave with this issue
Vtps bypass:
http://www.phearable.net/tech/...s.gif
Old Mar 26, 2007 | 01:47 PM
hialeahzbg's Avatar
thanks i really appreciate it...i will try this ...
Old Mar 26, 2007 | 03:50 PM
hialeahzbg's Avatar
i tried it and it worked...thank the gods at hondatech...
Old Mar 26, 2007 | 04:11 PM
93supercoupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicVX94 &raquo;</TD></TR><TR><TD CLASS="quote">I'd have to say it's the jdm front that's the source of your issues. It's annoyed that the rest of the car isn't jdm too...Ironically, I had the same problem. cross breeding ftl
Sorry, I couldn't resist </TD></TR></TABLE>
Old Mar 26, 2007 | 06:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hialeahzbg &raquo;</TD></TR><TR><TD CLASS="quote">i tried it and it worked...thank the gods at hondatech...</TD></TR></TABLE>
find a new tuner
Old Mar 26, 2007 | 07:34 PM
hialeahzbg's Avatar
it happened before the tuner....
DC2tuner86
Jul 22, 2010 05:25 PM
zenon8890
Oct 5, 2006 03:43 PM
Metal Head
Jun 3, 2006 03:53 PM
honura
Jun 27, 2005 06:55 PM
is3oo
May 22, 2004 11:16 PM
