turbo question??
Old Mar 29, 2007 | 06:17 PM
Hazymix's Avatar
Default turbo question??
i wanna run an fmu for now till i can afford neptune. Do i need to run a inline fuel pump or is a 255 walboro fuel pump fine??? im runnin a ls motor in a ek coupe. and is 5 to 7 psi saf it a fmu?? wit stock injectors???
Old Mar 29, 2007 | 06:33 PM
da_dude's Avatar
With stock injectors you'll need the fuel pump for sure. If it was me, I'll wait until I have everything togather before putting anything in the car. Be patient and good things will come.
Old Mar 29, 2007 | 06:49 PM
Hazymix's Avatar
Default Re: (turb20_vtec)
but will it be sufficient or should i put some 450 dsm injectors toooo??
Old Mar 30, 2007 | 07:12 AM
teddy_dc2's Avatar
you can't run dsm 450's with just an fmu. you need a chip or management to run them properly. there is a site i got my ecu chipped with cromepro basemap to run my 550's, after that you can ditch the fmu, and yes you will need a fuel pump. the 255lph will do just fine.
gtowni3
Mar 17, 2004 07:59 PM
untitled
Jan 7, 2004 03:29 AM
B18C-RnVA
Dec 28, 2002 11:58 AM
deacs
Sep 8, 2002 11:01 AM
DJ0820
Aug 1, 2002 11:56 AM
