CRX toe adjustment replacement - Honda-Tech - Honda Forum Discussion
Old 06-14-2010, 09:30 PM
Default CRX toe adjustment replacement
So, I was replacing the toe adjuster in my 91 rex and the bolt that bolts the toe adjuster to the frame seized to the toe adjuster. So I cut off the head of the bolt and was able to pry it out. Now I find that the nut in the frame has been pushed into who knows where and all i have there is a hole. Any Info on how I can get this fixed so that I can put the Toe Adjuster back in? The same thing happen with my tow hook bolts. Two of the nuts that were suppose to be on the inside of the frame are no longer there I know that with older cars there is going to be alot of people with this problem too so I would like to know any solutions that you have found, other then cutting into the frame and welding in nuts again. Any info would be great guys. Thanks
608_red_rex is offline
Old 06-15-2010, 07:08 AM
Tyson's Avatar
Default Re: CRX toe adjustment replacement
Tyson is offline
DaveSi677
Honda Civic (2006 - 2015)
199
11-18-2017 03:20 AM
k3ntegra
Suspension & Brakes
05-29-2017 10:10 PM
B_Swapped93
05-10-2017 02:47 PM
scheibler
04-22-2016 11:20 PM
EF8DayDreamer
03-26-2012 12:50 AM
Quick Reply: CRX toe adjustment replacement
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
