Turbo Ls/Vtec Build up
Old Aug 9, 2008 | 06:46 AM
JDMDAtehbeast's Avatar
Default Turbo Ls/Vtec Build up
Alright guys today I offically started my build. Just dropped the block off at my buddies dads so i should get it back by wednsday if i can get everything ordered..
The blocks a B18A1 and i'm getting AEBS sleeves put in and bored .20 over for my wiseco 8.5:1 pistons. The cranks getting micropolished and bull nosed. And once i figure out what rods im goin to use the whole bottom end will be getting balanced and blueprinted.
Onto the head. I don't really know what head would be better for a turbo build. But my buddy keeps tellin get a B16 head. But would a GSR head be better?? Any help yall can give is greatly appreciated. Mind you the head will be getting a p&p a 3 angle valve job and a set of turbo cams.
Now my goal for this setup is somewhere in the ball park of 600+ so what turbo do you think would be best for the setup..
Again any help is greatly appreciated...
Modified by JDMDAtehbeast at 4:09 PM 8/9/2008
Modified by JDMDAtehbeast at 4:10 PM 8/9/2008
Old Aug 9, 2008 | 12:57 PM
1.8turbolsvtec's Avatar
Default Re: Turbo Ls/Vtec Build up (JDMDAtehbeast)
6.5:1 pistons
Old Aug 9, 2008 | 02:15 PM
nytosc's Avatar
From: New York in the summer, South Carolina in the winter
Default Re: Turbo Ls/Vtec Build up (1.8turbolsvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8turbolsvtec &raquo;</TD></TR><TR><TD CLASS="quote">6.5:1 pistons</TD></TR></TABLE>
how else are you going to run 60psi of boost?
lol must be at typo
anyways- if both the heads are getting worked, id just get whatevers cheaper. As for the cams- DONT get turbo cams there a complete waste- Id get a set of skunk2 tuner series 1 cams imo
Old Aug 9, 2008 | 02:43 PM
lol my bad kinda typed it in a hurry. I'm running 8.5:1 pistons
Old Aug 10, 2008 | 08:58 PM
Aight guys little update, i ordered my eagle rods earlier today. And im gonna be pickin up a B16 head on wednesda. But i still dont know what turbo i should run. SC61 maybe?? And what kind of IM should i run instead of an edlebrock one??
Old Aug 11, 2008 | 12:38 PM
shotime's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMDAtehbeast &raquo;</TD></TR><TR><TD CLASS="quote">what kind of IM should i run instead of an edlebrock one??</TD></TR></TABLE>
Im doing a similar build but im working with a b20b and i asked myself the same question. I started to lean more towards skunk2 pro series IM because it can be ported to 75mm with a blox 74mm TB. thats the match im leaning to until i get the TB opening measurements on the edlebrock IM.
Old Aug 11, 2008 | 03:17 PM
Default Re: Turbo Ls/Vtec Build up (shotime)
well im trying to find an AIR manifold.. but im not havin much luck
leroyb
Jul 11, 2008 06:18 PM
Cyphear
May 3, 2007 09:35 PM
Unsought Devil
Jul 31, 2006 05:21 AM
Orangecivic251
Mar 23, 2004 11:57 AM
streetlvlhatch
Dec 4, 2003 01:27 AM
