garrett turbo
Old Aug 11, 2008 | 04:01 PM
adam00's Avatar
Default garrett turbo
would this be a good turbo to use on my stock jdm dohc f22b?? i plan on boosting 6-8psi on stock internals then over the winter i will take it all apart and put in turbo pistons and rods and i would like to make around 350whp would this turbo be able to make my stock dohc f22b have around 240whp at 6-8psi and then at like 20psi have 350whp???
http://cgi.ebay.com/ebaymotors...00515
Modified by adam00 at 5:16 PM 8/11/2008
Old Aug 11, 2008 | 04:10 PM
blwn95civic's Avatar
Default Re: garrett turbo (adam00)
..... which garrett turbo are you talkin about
Old Aug 11, 2008 | 04:17 PM
adam00's Avatar
Default Re: garrett turbo (blwn95civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blwn95civic &raquo;</TD></TR><TR><TD CLASS="quote">..... which garrett turbo are you talkin about </TD></TR></TABLE>
i forgot to put in the link
Old Aug 11, 2008 | 06:33 PM
street_ride14's Avatar
That turbine housing is too small for your 2.2L motor. You need at least a .63 a/r in order to see 350whp.
Old Aug 11, 2008 | 09:00 PM
adam00's Avatar
Default Re: garrett turbo (street_ride14)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street_ride14 &raquo;</TD></TR><TR><TD CLASS="quote">That turbine housing is too small for your 2.2L motor. You need at least a .63 a/r in order to see 350whp.</TD></TR></TABLE>
hows this one
http://cgi.ebay.com/ebaymotors...02843
Old Aug 12, 2008 | 09:03 AM
adam00's Avatar
bump
Old Aug 12, 2008 | 10:02 AM
TheShodan's Avatar
Moderator
That could work, but you could get it from Speed Trapp for the same price. A 60 trim is still a bit large for the F22b unless you plan to build the motor, if you're looking for a responsive setup. Stop looking for the "quick deal", and start researching for what hp you need, not just throwing up ebay ads for review.
Old Aug 12, 2008 | 01:00 PM
adam00's Avatar
Default Re: garrett turbo (TheShodan)
i am looking to make 375-400whp after i put in cams, new valve train, 3'' exhaust, forged pistons and rods, port and polished intake manifold and bored throttle body
Old Aug 14, 2008 | 10:09 PM
adam00's Avatar
bump
greygoose
Dec 30, 2007 05:23 PM
Exvtec king
17
Jul 10, 2007 11:07 AM
Not_So_JDM
Jun 22, 2007 11:09 PM
PRODIGYRSX
Nov 16, 2006 07:57 AM
jel002
Dec 30, 2004 12:15 PM
