spec stage 5 clutch
Old 08-15-2008, 08:08 AM
ral24_hct's Avatar
Default spec stage 5 clutch
Hello I need some fitback abut this clutch, if some one have expirence with this clutch it is good, I will intall this clutch in my b20 vtec turbo 460 whp and 340 tq
pls need and I dont whant to buy twin plate too expensive thnx
Old 08-15-2008, 08:32 AM
Hulk22's Avatar
Default Re: spec stage 5 clutch (ral24_hct)
i use it in my h22 set up i love mine great on the street better on the track
Old 08-15-2008, 11:08 AM
ral24_hct's Avatar
How much HP do you have in you H22
Old 08-15-2008, 06:51 PM
Hulk22's Avatar
Default Re: (ral24_hct)
last dyno was 511/380tq going for a new tune i will let you know how it gose
Old 08-16-2008, 11:28 AM
purpleh22's Avatar
I just switched to a Spec Stage 3+ from a Tilton twin disc. The factory rep recommended it when I talked with him. The Tilton would have been great for drags but to grabby for me, for the street.
The Spec Stage 3+ is good for over 490 ft. lbs. tq @ the flywheel.
I'm making 515 whp & 386 wtq. The Spec holds well, has light pedal pressure and is great for street use.
Old 08-16-2008, 02:04 PM
turbotypeR@SPEC's Avatar
I used the stage 5 in my Integra a few years ago when it was making 580whp and 430 lb ft. It worked great and lasted for two seasons.
I agree with purpleh22. the 3+ will work fine and be much better on the street. Are you using a cable or hydrolic tranny?
Old 08-23-2008, 05:34 PM
91TurboGSRCRX's Avatar
Default Re: spec stage 5 clutch (turbotypeR@SPEC)
I have a stage 5 aswell and ive been scedish to put it in my crx only because of how heavy the disc it self is did you have a problem with shifting at all
Old 08-23-2008, 06:52 PM
Default Re: spec stage 5 clutch (91TurboGSRCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91TurboGSRCRX &raquo;</TD></TR><TR><TD CLASS="quote">I have a stage 5 aswell and ive been scedish to put it in my crx only because of how heavy the disc it self is did you have a problem with shifting at all</TD></TR></TABLE>
I never had a problem shifting nor have I heard of anyone else having a problem.
h22killer
04-01-2015 10:00 AM
chingo450r
02-25-2013 08:50 PM
H2B-EK4
11-01-2009 02:45 PM
fukenricen
01-10-2009 09:12 AM
Quick Reply: spec stage 5 clutch
