GREDDY E-01, QUESTIONS, info...ect
Old Aug 7, 2008 | 01:23 PM
riddlinkid1986's Avatar
Default GREDDY E-01, QUESTIONS, info...ect
First off, like to say this is a good item an as a boost controller it works geat.
Im posting this cause THERE IS NO E-01 help any where, even through greddy its almost impossible to get what i need as far a info.
I have been DIGGING for over 4 months now, an still have so many questions that seems like no one can answer. I know there are a good number of people on HT that use this boost controller. So please feel free to share your info
Questions-
Dose anyone have the instruction manual for the Optional harness for MPH,THROTLE, WIDEBAND A/F?
Can i just hook up the Wideband Sensor to the e-01? Cause i hear of people doing so. True? False?
Has anyone ever hooked the Throtle & MPH on the e-01? can you take a pic of the harness an tell me where wires go?
Im really good with electrical! An reading digrams, but im going nuts trying to find this info!
Anyways, thank you for reading, an if you have info anyone wants to post about the e-01 or problems to look for....ect please do so
Old Aug 7, 2008 | 03:38 PM
Default Re: GREDDY E-01, QUESTIONS, info...ect (riddlinkid1986)
From what i under stand, On the Optional Harness, That plugs into the MAIN unit for the Greddy e-01, There is a "ANALOG SIGNAL INPUT 1 (a/f 0-5v signal)" an a A/F Ground.
So, Im guessing that those would be hooked up to the map sensor? Just as you would hook up a VAFC to the map sensor.
ANALOG SIGNAL INPUT-WHITE (a/f 0-5v signal) =MAP SIG. in?
ANALOG SIGNAL INPUT-Grey (TPS) throtle
ANALOG SIGNAL INPUT-Green (Subaru v. clap boost cut)????-ANYONE EXPLANE?
ANALOG SIGNAL INPUT-Black (A/F GROUND)=MAP SIG out?
ANALOG SIGNAL INPUT-Blue (I/J DUTY CYCLE) ?????-ANY EXPLANE?
ANALOG SIGNAL INPUT-Light Blue (Crank/Cam angle signl.
Im trying to digure these out, can someone trace theres an give me some input!
Any info would be great! thanks for reading!
Old Aug 8, 2008 | 11:36 AM
bump! over 50 people seen this a no one can add some input? help? BUMP!
riddlinkid1986
Engine Management and Tuning
May 5, 2009 10:37 AM
westcoaststyle
Nov 5, 2003 05:44 AM
gstintegra92
Oct 18, 2003 07:23 PM
bruthaboost
Jul 26, 2002 09:02 AM
