turbo question
Old Aug 10, 2008 | 06:23 PM
dadsvtechonda's Avatar
Default turbo question
i have a 95 ex with a greddy kit on it 5psi nothing crazy need to add check valves to trick the map sensor can any one tell me how to do a correct check valve set up for the map sensor ??? P.S. HONDAS RULE LOL
Old Aug 10, 2008 | 07:22 PM
TheShodan's Avatar
Moderator
Default Re: turbo question (dadsvtechonda)
Greddy kit should come with its e-manage that will correctly "trick" the ECU. Did you not get that with your kit?
Old Aug 10, 2008 | 08:17 PM
dephtone's Avatar
Personal preference I would ditch the Greddy E-manage. I had nothing but problem with those. Freezing up resetting etc. I would sell that and invest in hondata or maybe even chrome. Are you planning on going past 10psi? If so just buy a new motorola 2.5 bar or if your want plain and simple the omni/hondata 4bar. plugs right into the stock map location.
Old Aug 11, 2008 | 05:37 AM
Default Re: (dephtone)
didnt come the emanage i was thinking aboutr getting a map sensor check valve
Old Aug 11, 2008 | 07:58 AM
TheShodan's Avatar
Moderator
Default Re: (dadsvtechonda)
You need more than check valves. You need to be able to have enough fuel to work with the turbocharger. The "blue box" that came with it was able to help with that, since it had larger injectors that came with the kit. You have to control the fuel at the same time, and no, do not use an AFC.
skip122
Apr 21, 2006 12:43 PM
dmah
Jun 3, 2003 12:10 PM
Sivik
May 8, 2003 07:28 AM
Blackcivic1
Nov 4, 2002 04:03 AM
FOrSfEd
May 29, 2002 06:38 PM
