Blitz dual boost solenoid with S300?
First of all will this unit work with the Hondata S300?
Second, where does the "IN" and "OUT" ports hook up to? (vacuum/pressure ect).
Third, theres a blue wire coming from one solenoid and a purple coming from the other, I assume these are the signal and go to the ecu? and the white coming from both are 12v?
Last, what frequency does it work with?
I just got an S300 and have a blitz solenoid laying around. If i can use it and not have to buy another solenoid, it'd be a plus. I've searched on here but have only seen, the mac/aem, perrin, apexi, greddy solenoids talked about.
heres a pic. its the big black box.
Thanks in advance.
-Zol
Modified by reaction360 at 7:11 AM 8/11/2008
Thanks in advance.
-Zol
Mr. Badwrench
Re: Blitz dual boost solenoid with S300? (reaction360)
honestly, sell the sbc id, it is a great boost controller, but with all the features of the s300 boost by gear, v.s. and rpm dependent, it is a no brainer.
Re: Blitz dual boost solenoid with S300? (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">honestly, sell the sbc id, it is a great boost controller, but with all the features of the s300 boost by gear, v.s. and rpm dependent, it is a no brainer.</TD></TR></TABLE>
haha, I don't think you understand my question. I wanna run the blitz boost solenoid with the S300.
if its a 2 wire PWM solenoid which it pretty much has to be im sure it will work. having never used that boost controller i'd imagine coming from the compressor housing it would T going to the side port of the wastegate and the "in" port on the solenoid. and i'd guess that the "out" would go to the top port on the wastegate.
feed switched 12v to one side and the ecu will pulse ground to the other side.
solenoid looks pretty big and bulky i'd probably go with a aem style solenoid
feed shop air or something to the "in" port and see if anything comes out of the "out" port. if it does not.......put power/ground to the solenoid and try it again. that will let you know if its a normally open or normally closed solenoid
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reaction360 »</TD></TR><TR><TD CLASS="quote">
haha, I don't think you understand my question. I wanna run the blitz boost solenoid with the S300.</TD></TR></TABLE>
i do, why separate something you can sell for 300 ish, and get a 20$ mac soleniod, and pocket some cash?
i do, why separate something you can sell for 300 ish, and get a 20$ mac soleniod, and pocket some cash?</TD></TR></TABLE>
Dude, I never even said I had a whole kit. All I have is the solenoid
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">was goin by the pic sorry man.</TD></TR></TABLE>
its all good man, thanks for trying
I think I'll just give in and buy a mac valve.
RACEPAK
02-01-2010 04:50 PM
xander1100
Engine Management and Tuning
06-05-2009 05:17 AM
THEDirtyDseriesWOOT
06-26-2007 11:40 AM
