Honestly - What turbo? Vitara build
I've built myself what I thought was a nice "budget" build for my DD.
D16Z6
75.5 Vitaras
TT rods
ACL bearings
OEM HG
OEM WP
OEM TB
Zex cam
Comp Cam springs + retainers
Supertech valves
After doing a little bit more reading, I've found my compression to be 7.5:1
The turbo setup I chose was a garret t3/t4 .57 trim turbo, log mani, 3" dp / 3" kteller exhaust, tial 38mm waste gate.
I don't really care about dino #'s. I want a decent DD, and decent 1/4 times
I don't want to be a slug for the first bit of each gear
Suggestions? Anyone else running this similar setup?
I'm probably going to have the head ported / polished.
Other then that I think thats it in terms of machine work.
D16Z6
75.5 Vitaras
TT rods
ACL bearings
OEM HG
OEM WP
OEM TB
Zex cam
Supertech valves
Re: (tony413)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony413 »</TD></TR><TR><TD CLASS="quote">look into a GT2871R </TD></TR></TABLE>
Will do.
Anyone have input on this build though?
I know i'm not the only one runnin' this setup.
Will do.
Re: (Xathine)
gt2860rs or gt2871r if you have money. It will perform on a d16.
t3 super 60 if you want something similar but not bb.
Im running a t3/t04e 50 trim, .48 ar and i like it. full boost by 3500rpm.
I used to have a t3/t04e 60 trim. Laggy as hell but pulled hard uptop.
I am goign for a gt28 myself now once i retire the t3/t04e.
Re: Honestly - What turbo? Vitara build (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan »</TD></TR><TR><TD CLASS="quote">Yick. 7.5:1 on a 57 trim. </TD></TR></TABLE>
Shouldnt be a problem... Speed Factory EG (JFK78) has a Vitara/Eagle build that should be also in the 7.5:1 CR. They use a t3/t4 57 trim turbo and they run 10's all night with 138+mph trap speeds...
If you want more compression ratio you should have gone with our Custom length D16 I beamm forged rods.. It bumps the CR to 8.5:1 on the Z6 with Vitara pistons.
Re: Honestly - What turbo? Vitara build (fjt)
James' dyno graph has a nice nice curve. Prolly one of the best I've ever seen for a dseries for average power.
Re: Honestly - What turbo? Vitara build (narfdanarf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by narfdanarf »</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
damn they rev'd the **** out of that D-series kinda looks like a B-series dyno
Re: Honestly - What turbo? Vitara build (Xathine)
well mines kinda similar
75.05 vitaras y7 block
eagle rods
acl bearings
z6 stock head but ported
apexi ballbearing turbo kit very fast spooling
hondata s300
RC 550 injectors
looking to dyno mine in couple of weeks..
eagle rods
acl bearings
hondata s300
RC 550 injectors
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fjt »</TD></TR><TR><TD CLASS="quote">Shouldnt be a problem... Speed Factory EG (JFK78) has a Vitara/Eagle build that should be also in the 7.5:1 CR. They use a t3/t4 57 trim turbo and they run 10's all night with 138+mph trap speeds...
Your custom length rods were not available when I put my bottom end together.
I would recommend a "Disco Potato" for your setup - because you mentioned you want a nice DD and not a dyno queen.
Ditch the 57trim - that 7.5:1 compression with that size turbo = sleepy time until 5k rpm.
Any GT28 will be good.
Re: (Unsivil_audio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Unsivil_audio »</TD></TR><TR><TD CLASS="quote">imo, 57 trim is a great turbo on the street. </TD></TR></TABLE>
Highway Terror
Highway Terror
Re: (Autoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autoworks »</TD></TR><TR><TD CLASS="quote">.70 a/r 50 Trim </TD></TR></TABLE>
this would have to be from BW you forgot to mention that since thats the only way to get the .70 ar
Re: (spoolin turbo s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolin turbo s »</TD></TR><TR><TD CLASS="quote">
sorry, yes, it is a Bullesye Power 50 trim .70 a/r I am referring to. I've sent out several for SOHC builds with great feedback. I personally think the 50 is a great fit for the D series.
