Good setup for boost?
Old Aug 6, 2008 | 06:50 PM
dc2ls-vtec's Avatar
Default Good setup for boost?
Hey,
I've got an LS-V with a B16B head, B18A Bottom, and ITR pistons. Some people on here have said that the compression ratio is too high because of the pistons, others say it should work fine. 2 questions:
1) Can I get reliable power running 6-8lbs of boost with this setup?
2) Would going with a supercharger be safer than a turbo?
Old Aug 6, 2008 | 07:23 PM
b16bri's Avatar
Default Re: Good setup for boost? (dc2ls-vtec)
turbo or supercharger personell prefrence but turbos better in my eyes and will deff make more power. and yes 6-8 psi will be ok as long as you have enough fuel and a good tune you'll be fine. what is the cr ?
Old Aug 7, 2008 | 05:03 AM
dc2ls-vtec's Avatar
Default Re: Good setup for boost? (b16bri)
The CR is the unknown at this point. I bought the car the way it is, so I'm not sure which head gasket he used. I'm not sure what his intention was when he was building it.
Old Aug 7, 2008 | 05:09 AM
dc2ls-vtec's Avatar
Correction: I just dug up the original ad for the car and found out it has CTR Pistons. Will that make a difference?
Old Aug 7, 2008 | 05:24 AM
Boostn B20's Avatar
yessir. im new to boost myself. but assuming the previous owner had the block bored .20 over, used a 3 layer gasket, ur cr should be something like 11.7:1 if the head was not shaved. and like i said im new to boost myself. but 11.7:1 + boost= good *** tune * cross your fingers.
Old Aug 7, 2008 | 10:37 AM
greygoose92's Avatar
Default Re: (Boostn B20)
My question is how much power are you trying to make on this setup? Sounds like the car was setup to be all motor.
Old Aug 7, 2008 | 01:06 PM
dc2ls-vtec's Avatar
Default Re: (greygoose92)
I'm looking for 250-300 hp, nothing too big.
Freshdot
Nov 15, 2012 07:10 AM
mels_ls_vtec
Sep 16, 2010 08:20 AM
tremblay
Oct 27, 2009 05:03 PM
Chris Crane
Jan 15, 2008 07:42 PM
D1andOnly
Nov 27, 2005 05:00 PM
