What do i need to make this work....
Old Aug 10, 2008 | 01:42 PM
B18Sleeper's Avatar
Default What do i need to make this work....Eclipse turbo on B16
Ok i have a garrett .48 A/R tr0760 turbo off a 98 gst eclipse. what can i do to make this turbo work on my b16a2 block? it is a water cooled turbo and was wondering if i can use this turbo on my car and if i have to fab my own mani or can i buy one to match and the down pipe is a wonder too. thanks
Modified by B18Sleeper at 3:04 PM 8/10/2008
Old Aug 10, 2008 | 02:30 PM
B18Sleeper's Avatar
Default Re: What do i need to make this work....Eclipse turbo on B16 (B18Sleeper)
anyone? looking to put this on stock internals.
Old Aug 10, 2008 | 04:10 PM
DaveF's Avatar
check out http://www.spoolinperformance.com i belive they make dsm flanged turbo manifolds for hondas
Old Aug 10, 2008 | 05:26 PM
B18Sleeper's Avatar
Default Re: What do i need to make this work....Eclipse turbo on B16 (DaveF)
but is this a good idea? until i get my gsr to build up?
Old Aug 11, 2008 | 08:43 AM
TheShodan's Avatar
Moderator
No. Simply put, this is NOT a good idea. You need to concentrate on the right equipment now, so that you're not replacing a ton of parts later when you "build it up". you can still get a good sized turbo to work for you for now, that can work for the B16A2, then retune and turn up the wick, or easily replace the turbocharger w/ a larger unit later. It's best not to half-*** this, just to say you have boost.
Old Aug 11, 2008 | 07:23 PM
B18Sleeper's Avatar
Default Re: What do i need to make this work....Eclipse turbo on B16 (TheShodan)
But I don't see the point in putting all this money into a little bigger turbo that i will have to replace a few months down the road when i get a GSR block to build. Because i will need a bigger turbo at that time to push the numbers i want out of the GSR block. So instead you want me to buy all new parts to boost a stock block that i will have boosted for prolly 6 months then park it and rip it out for the GSR build. I mean i got an offer on a greddy fmic, hks ssqv bov, and an autometer boost gauge. The b16a2 i have is not what will be in the car 6 months to a year down the road cause after i get my 240 legal and tagged it will become my DD. Then the civic will be parked and ripped apart to get a new freshly build motor and an overhaul from inside out. So if I may why is this such a bad idea and why would it be half-assed? Hope I dont sound like i am being smart just wondering. thanks
Old Aug 11, 2008 | 07:38 PM
nytosc's Avatar
From: New York in the summer, South Carolina in the winter
considering you will be using every part you use on your b16, will be used on the gsr as well, why not just do a solid setup right now? Get a quality intercooler (the greddy is good) good piping thats bead rolled, silicon couplres with t bolt clamps. Now get a decent sized t3to4e turbo such as a 57 trim, along with a good manifold DP setup-
only thing you will be changing when u go to the GSR is the oil pan, and possibly turbo- what are your goals?
Old Aug 11, 2008 | 08:37 PM
blinx9900's Avatar
Default Re: What do i need to make this work....Eclipse turbo on B16 (nytosc)
that tiny turbo falls off in power production at 5500rpm on an eclipse, thats where our engines start to come to life, its going to suck *** but if you want to do it its your car, the wise have spoken.
Old Aug 13, 2008 | 07:54 PM
B18Sleeper's Avatar
Default Re: What do i need to make this work....Eclipse turbo on B16 (blinx9900)
well i am going to fab my own IC piping, and my power goals are unknown really. i want the car to run at like 300 or 350 first then work my way up till I get the car I want. so i dont know my true power goals. but if this is a bad idea i wont do it just fab up the piping and get the little parts like fmic, bov, etc. thanks guys
Old Aug 13, 2008 | 09:43 PM
TheShodan's Avatar
Moderator
Again, this is a bad idea. Get the right build right the 1st time.
Old Aug 13, 2008 | 10:23 PM
KeyserSoze's Avatar
Dude, either you want the help or you don't. If you're not gonna listen then why ask? There are a LOT of people who have done what you are trying to do and it ends up being the more difficult way of doing things. People are just trying to save you a lot of work. If you don't want to take the advice then you have two options.........
1) Do the research yourself and figure out that what people are telling you is correct, or.....
2) Do it the hard way and learn from your mistake.
GL.
Old Aug 14, 2008 | 01:59 PM
B18Sleeper's Avatar
Default Re: What do i need to make this work....Eclipse turbo on B16 (KeyserSoze)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Sleeper &raquo;</TD></TR><TR><TD CLASS="quote">well i am going to fab my own IC piping, and my power goals are unknown really. i want the car to run at like 300 or 350 first then work my way up till I get the car I want. so i dont know my true power goals. but if this is a bad idea i wont do it just fab up the piping and get the little parts like fmic, bov, etc. thanks guys </TD></TR></TABLE>
read the bold print. if its that bad of an idea i wont do it. but i am still gettin the hks ssqv bov, or other odds and ends that are not bad quality or a bad choice. thanks again for everyones input but please dont sit here and tell me i aint listening when my last post stated i wasnt going to do this. but again thanks
Old Aug 14, 2008 | 07:44 PM
B18Sleeper's Avatar
what about this turbo with slight shaft play? Turbonetics 60-1 t3t04 stg1 .63 a/rTurbo
KnA2524
Jul 31, 2008 07:13 AM
slowlx
Feb 6, 2005 09:54 AM
1BadDC2
Mar 20, 2004 02:49 PM
blackhyb
Sep 28, 2003 08:41 PM
