HELP... How do I Remove DSM resistor box.
Old Aug 15, 2008 | 07:45 AM
eL_cArLos's Avatar
Default HELP... How do I Remove DSM resistor box.
I recently purchased an EG coupe with a DSM 440's wired in along with a resistor box...I removed the box, Now my car wont stay at idle when I start it up, starts up perfectly fine just dies out though... I am pretty sure its the wiring that from where the DSM's once were. Can someone please shed some light on where I can find the correct wiring.. Thank YOU.
Old Aug 15, 2008 | 08:21 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: HELP... How do I Remove DSM resistor box. (eL_cArLos)
if you arent going to use them ever again, cut the connector off, and solder all 5 wires together. (if thats the only issue)
Old Aug 15, 2008 | 10:06 AM
eL_cArLos's Avatar
Default Re: HELP... How do I Remove DSM resistor box. (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">if you arent going to use them ever again, cut the connector off, and solder all 5 wires together. (if thats the only issue)</TD></TR></TABLE>
I can just solder all 5 together to one end? I dont have to slip them back into the plug?
Old Aug 15, 2008 | 01:49 PM
Mr. Badwrench
what i am getting at, is you have 12v into the box, and 4 out, if you are using saturated injectors, just splice the 12v into the resistor box to the 4 other wires. thats all that is needed to be done.
Old Aug 15, 2008 | 02:04 PM
EJ1 wilcox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">what i am getting at, is you have 12v into the box, and 4 out, if you are using saturated injectors, just splice the 12v into the resistor box to the 4 other wires. thats all that is needed to be done.</TD></TR></TABLE>
This is 100% true.
I've done this on a number of cars. I always boost, then remove and return the car to stock before I sell it.
Old Aug 15, 2008 | 05:58 PM
eL_cArLos's Avatar
Default Re: HELP... How do I Remove DSM resistor box. (EJ1 wilcox)
thanks for the info, I'll try it tonight.
Old Aug 16, 2008 | 12:47 AM
eL_cArLos's Avatar
So I tried just soldering all those wires together and still no normal idle.... Could there be something else I'm doing wrong?
Old Aug 16, 2008 | 09:40 AM
eL_cArLos's Avatar
HELP
Old Aug 16, 2008 | 03:55 PM
eL_cArLos's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eL_cArLos &raquo;</TD></TR><TR><TD CLASS="quote">HELP </TD></TR></TABLE>
Old Aug 16, 2008 | 04:13 PM
EJ1 wilcox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eL_cArLos &raquo;</TD></TR><TR><TD CLASS="quote">So I tried just soldering all those wires together and still no normal idle.... Could there be something else I'm doing wrong? </TD></TR></TABLE>
That's how you remove the resistor box. I'm sure there are other things that could be wrong though.
Old Aug 16, 2008 | 10:16 PM
eL_cArLos's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">That's how you remove the resistor box. I'm sure there are other things that could be wrong though. </TD></TR></TABLE>
Thanks for the HELP I am gonna trouble shoot see what I come up with.
Old Aug 16, 2008 | 11:15 PM
da_dude's Avatar
Of course it's not going to idle with those 450cc injectors on.
Old Aug 17, 2008 | 07:11 AM
eL_cArLos's Avatar
Default Re: (da_dude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by da_dude &raquo;</TD></TR><TR><TD CLASS="quote">Of course it's not going to idle with those 450cc injectors on.</TD></TR></TABLE>
Maybe you should read the whole post....
NegativeXero
Jul 18, 2006 08:56 PM
lilxvtecxpwr
Apr 12, 2004 05:36 AM
Nextelbuddy
Dec 5, 2003 10:13 AM
cornhusker
Sep 24, 2003 06:06 AM
