fuel pump question
Old Aug 17, 2008 | 06:51 PM
turboorsupercharger's Avatar
Default fuel pump question
have a 97 prelude that i'm turboing and i wondering if i needed to get a high pressure fuel pump or can i use the stock pump?
Old Aug 17, 2008 | 07:24 PM
MiraiZ's Avatar
Default Re: fuel pump question (turboorsupercharger)
depends on what your goals are and what your set up will be
Old Aug 17, 2008 | 07:28 PM
Default Re: fuel pump question (MiraiZ)
for the mean time ill only be run about 8 to 10 psi its a basic t3t4 hybrid turbo with intercooler and all down the run i want to pull the engine and completely build it from bottom up.
Old Aug 17, 2008 | 07:41 PM
MiraiZ's Avatar
you should be okay with stock for a while, but I would swap the injectors out for higher capacity ones.
I'm currently running a stock pump with 560cc injectors out of an Evo. My tuner told be that I'm approaching the threshold and should upgrade the pump soon if I want more power, but I'm currently running just a tad under 300WHP so its no rush...
Old Aug 17, 2008 | 08:05 PM
cool thats good news i really didnt want to buy a new one and then try to rip the old one out. even tho its not that hard its just in a pain in the *** space, under the back seat . yeah i probably be putting out around 340 with the turbo. then i will have to get it tuned
Old Aug 17, 2008 | 08:19 PM
MiraiZ's Avatar
If you're thinking of doing over 300whp, then I would consider a fuel pump. They're cheap ($100??) and only takes about an hour avarage to install one. Just get a friend to help up out...its probably about as hard as changing a tire, and as messy as changing the oil or fuel filter.
Old Aug 17, 2008 | 08:26 PM
i know they're not hard to change. its just a pain to take the back seat out then try putting it back in. but if i need it then im going to have to do it right? so then what size injectors do you think im going to need?
Old Aug 17, 2008 | 09:32 PM
pcguy760's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboorsupercharger &raquo;</TD></TR><TR><TD CLASS="quote">i know they're not hard to change. its just a pain to take the back seat out then try putting it back in. but if i need it then im going to have to do it right? so then what size injectors do you think im going to need?</TD></TR></TABLE>
LOL, we Honda guys actually got it easy with the fuel pump! Alot of other vehicles require you to drop the whole fuel tank from UNDER the car - that crap sucks especially when you got gas in the tank!! If your goal is 300Whp I think some 550cc would be good and personally I think you should get the fuel pump as well. That's what I am currently running on my turbo H22A - 550cc Injectors and the 255Lph Walboro.
Old Aug 18, 2008 | 07:02 PM
Default Re: fuel pump question (pcguy760)
haha yeah you have a point there.. thanks for the info really helpful!!
turbolsvtecej1
Sep 7, 2014 04:06 PM
prelude2.2
Oct 22, 2012 06:41 AM
Jimster480
10
Dec 3, 2008 09:07 PM
Todapwr
May 12, 2004 07:51 PM
Anubyss
Apr 23, 2003 06:54 AM
