Valves or messed up turbo?
So i can't tell what is up with my turbo teg. After a hard day at the auto cross earlier this year, my car started making a faint tapping/fluttering sound only under throttle. It also only makes this sound when it is gear. It won't make the sound when the car is in neutral and the motor is revved. I can't tell if i have a valve train problem or if there is something broken with my turbo. my car is open down pipe, so it hard to tell exactly where the sound is coming from or what the sound is. Please help guys!!!
Mr. Badwrench
Re: (Whiteintegra)
only makes noise in gear clutch out? ok either the trans is talking, or the turbo only makes noise under load.
kinda hard to diag this type of stuff over the internet.
HELLO,GOOD MORNIN'
Re: (Whiteintegra)
jon can you do a leak down test?
datalog on your Chrome ECU
check your spark plugs for the backfire.
BTW im not on aol my LapTop is down and my wifes vista is stupid and wont let me get on
Re: (HybridcivicLS-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridcivicLS-T »</TD></TR><TR><TD CLASS="quote">jon can you do a leak down test?
BTW im not on aol my laptop is down and my wifes vista is stupid and wont let me get on</TD></TR></TABLE>I'm pretty sure you laptop is over heating. Install cortemphttp://www.alcpu.com/CoreTemp/CoreTemp.zip on your laptop and see what your processor temp is. If it is over 70 degrees C, then you processor driver is not functioning correctly. If your processor driver isn't functioning correctly, reinstall them and the problem should be fixed. good luck!
Re: Valves or messed up turbo? (Whiteintegra)
could it be related to his blow off valve possibly a leak in the vacum line ? The reason i say this is it only occures under load not at idle ?
Re: Valves or messed up turbo? (linx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by linx »</TD></TR><TR><TD CLASS="quote">could it be related to his blow off valve possibly a leak in the vacum line ? The reason i say this is it only occures under load not at idle ?</TD></TR></TABLE>I did loosen my bov a few days ago. As a matter of fact, i know its very loose! either way, im off to start trouble shooting. wish me luck guys!
ok, so i popped my hood and found 2 exhaust manifold bolts missing and 2 bolts from turbo to manifold missing.
Turns out that my bov was tightened all the way down. I'm going loosen it and/or add springs to it. Hopefully this will help.
Here is a link to the video. http://www.youtube.com/watch?v=CKfUfvyRpug
Yo, i don't have pneumatic tools!
abmerop18
03-27-2006 05:53 AM
