What plug gap has worked well?
Old Aug 17, 2008 | 09:36 AM
Rob97'SH's Avatar
Default What plug gap has worked well?
H22 stock engine 6.5-7 psi Garrett t60-1 turbo. Was taking the advice of others about plug gap. Set mine to .75mm (stock is 1.1mm). Those of you that have h22, what gap are you running? Any disadvantanges?
Old Aug 17, 2008 | 10:32 AM
88ED8's Avatar
Default Re: What plug gap has worked well? (Rob97'SH)
.030 runs clean
Old Aug 17, 2008 | 11:55 AM
LSVtechnologytur...'s Avatar
i've used .028 .. then started blowing it out with higher boost.. and eventually ended up at like .020
Old Aug 17, 2008 | 05:35 PM
Eklsv-t's Avatar
i use ngk bkr7e pregapped on my ls vtec turbo boosting 15psi daily driver
Old Aug 17, 2008 | 06:03 PM
HiProfile's Avatar
Default Re: What plug gap has worked well? (Eklsv-t)
The only disadvantage with a smaller gap is that you have a very slight chance of a misfire (not igniting) during light load. You THEORETICLY could get slightly worse fuel ecconomy during regular driving with a small gap. Since you aren't making a fuelsaver car, don't give it a second thought. Run the .75mm/.029" gap like most others do, and gap smaller if you NEED to when/if you crank the boost up.
FYI the reason you need to decrease the gap is because you have more atoms between the strap & electrode (at a fixed spacing) when you 'boost' than during low load, such as high-vac idle. 'Blowing out the spark' is little more than putting too many atoms between the groundstrap and electrode, preventing it from arcing across the gap.
Tytank7
Aug 4, 2008 07:05 AM
gsrtpower
Jul 23, 2007 08:54 PM
high_revs
Oct 30, 2005 01:01 PM
booscivic
Jan 20, 2004 10:27 AM
swissturbo
Jun 14, 2002 11:33 PM
