High Vacuum on Decel
Old Aug 18, 2008 | 03:47 PM
88crxvtec's Avatar
Default High Vacuum on Decel
I've noticed that when I let off the gas in my b16 that my boost/vacuum gauge goes to 60cmhg (metric gauge). I have a feeling it may be time to re-ring this winter as it's been boosted for 2 years. It's a built b16, Weisco Pistons, Eagle Rods, Darton Sleeves.
Thanks!
Old Aug 19, 2008 | 04:33 AM
nsxmatt's Avatar
Default Re: High Vacuum on Decel (88crxvtec)
60cm hg is equal to about 23-24 inch on my Autometer which isn't too far off from normal. Mine pulls 20-21 on decel. That usually indicates a strong motor I thought. Maybe someone else can chime in and tell you to go ahead and boost the hell out of it the way it is.
Old Aug 19, 2008 | 07:39 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: High Vacuum on Decel (nsxmatt)
depepnding on overlap, but yeah that sounds about normal to me.
Old Aug 19, 2008 | 11:33 AM
88crxvtec's Avatar
Default Re: High Vacuum on Decel (boostedcivicsir)
Ok well I guess it's time to see what over 14lbs feels like.
Old Aug 27, 2008 | 09:12 PM
JaredKaragen's Avatar
high vac on decel is normally cause you removed the PCV setup; that controlled vacuum leak that's engineered in
Old Aug 28, 2008 | 05:18 AM
2point2's Avatar
Perfectly normal.
Old Aug 28, 2008 | 11:54 AM
LastGenEK's Avatar
Default Re: (2point2)
Normal.... 60chm isnt that high but its healthy!
Old Aug 28, 2008 | 12:05 PM
88crxvtec's Avatar
Default Re: (LastGenEK)
Thanks guys, just bumped up to 17psi with no problems.
Old Aug 28, 2008 | 12:08 PM
nsxmatt's Avatar
20. Don't be a puss.
Old Aug 28, 2008 | 01:27 PM
ABK's Avatar
ABK
Default Re: (nsxmatt)
How much boost does your map sensor read? Use it, lol. Yea I see 26" with pcv system removed.
Old Aug 28, 2008 | 04:31 PM
88crxvtec's Avatar
Default Re: (ABK)
might crank it up a bit more tomorrow night and run your del slow
I have a 3bar so I think it will work.
Old Aug 29, 2008 | 04:00 AM
boosted k20's Avatar
Default Re: (88crxvtec)
my all motor setup use to pull close to 29IN-HG on decel. perfectly normal. U usually have a problem with the motor if your vacuum at idle is low (say below 19 In-Hg)
grizzled
Jul 9, 2006 09:46 PM
turbochargeb18c
Jan 14, 2006 08:38 PM
bennyhonda7
Jun 7, 2005 01:19 PM
Gsr_Hybrid_theory
Feb 7, 2005 04:38 PM
93LSivic
Sep 25, 2001 09:54 AM
