Synapse BOV and Boost control
Old Aug 9, 2008 | 04:37 PM
GReddy_Civic's Avatar
Default Synapse BOV and Boost control
This is what I have so far, the bov is a synapse and the boost controller is for hondata. I just want to make sure it's correct (keep in mind the w/g is internal)
Old Aug 9, 2008 | 04:45 PM
tony413's Avatar
ummm yeah so i cant tell jack crap from looking at those
Old Aug 9, 2008 | 05:01 PM
Default Re: (tony413)
Haha, I kinda figured, sorry. Ok, the waste gate (internal) is ran to the boost controller solenoid. On that same vacuum line, the 3rd nipple on the bov (the lone one on the side) is T'd into it. The two nipples on the rear of the bov go to the vac manifold. Then the one line on the solenoid goes into the vac mani.
Old Aug 9, 2008 | 05:08 PM
tony413's Avatar
then yes you seem to be set-up fine ports A & B need a constant unregulated vaccum source and port c just needs a boost source
oh an ifyou want just tee ports A & B together an run one line to the vaccum source
Old Aug 10, 2008 | 06:01 AM
WOOT! awesome man thanks. And yea, ports A and B are already T'd together
Old Aug 13, 2008 | 08:01 AM
iamsynapse's Avatar
New User
Default Re: (GReddy_Civic)
You can take that recirc fitting off too if you want. It'll look cleaner.
Old Aug 13, 2008 | 08:38 AM
legomytego's Avatar
its setup correct and you can take the fitting off and it will not hurt anyhing i run the same bov works great not very loud unless you have the anti stall tho
GReddy_Civic
Aug 9, 2008 11:17 AM
TurboEM1
Sep 12, 2007 04:05 AM
Si Shane
Nov 20, 2004 08:07 PM
Smoothy
Nov 14, 2001 08:48 PM
GruvyTune
Oct 22, 2001 06:16 PM
