greddy type s bov install
Old Aug 17, 2008 | 08:56 AM
TURKISHFORCE's Avatar
Default greddy type s bov install
hi agains from germany..
how can i install the bov aright correct with two vaccum pipe..
ore is one pipe vaccum line enough..
please info...
http://img392.imageshack.us/my...4.jpg
Old Aug 17, 2008 | 05:17 PM
kyden's Avatar
Default Re: greddy type s bov install (TURKISHFORCE)
just put the hose on the bigger one. don't worry about the smaller nipple.
Old Aug 17, 2008 | 06:32 PM
HiProfile's Avatar
Default Re: greddy type s bov install (kyden)
Putting the small nipple on the charge piping (before the throttle body) will slightly increase response, but will decrease holding power. You may have to increase the spring to compensate. That would lead to less overall flow, as the valve would not open as far. So only connect it if your bov is opening slow.
BTW your diagram for the wastegate looks wrong. Assuming thats a common WG design like a TiAl, you should put it on the lower nipple. Putting it on the top nipple only will keep it sealed, leading to crazy overboost.
Old Aug 19, 2008 | 04:29 AM
Default Re: greddy type s bov install (HiProfile)
thanks for infos...
Old Apr 2, 2011 | 10:16 AM
redlude92's Avatar
so wait... is this a blow off valve? or a waste gate? in either (WG or BOV) where do you connect that vacuum line too?
im trying to turbo my 03 em2, but i only see write ups on things i need, and not "how to" install my turbo.. can anyone lead me in the right direction?
Old Apr 2, 2011 | 11:31 AM
BLU CIVIC's Avatar
Track Advocate
i just installed this bov...vacuum line goes on top like kyden mentioned
regarding the lower nipple:
http://www.b15sentra.net/forums/showthread.php?t=113046
Old Apr 2, 2011 | 11:37 AM
redlude92's Avatar
But where does the other end of the vacuum line go? Lol sorry for the super noob question, like I said, I've been searching everywhere for a how to Turbo install write up but can't find one.
Old Apr 2, 2011 | 11:42 AM
BLU CIVIC's Avatar
Track Advocate
look in my last post
Old Apr 2, 2011 | 11:48 AM
redlude92's Avatar
Oh okay I see, thanks man.
4dek
Jun 1, 2008 05:39 AM
hotimportcrx
Jun 9, 2005 10:03 AM
B16Civic93
Mar 8, 2005 07:36 AM
Havokmkr
Apr 16, 2003 03:47 PM
Troy
Nov 17, 2002 11:29 AM
