Too much?
Old Aug 7, 2008 | 01:10 PM
Panda Eg6's Avatar
Default Too much?
Ok I am planning on boosting a stock block b series. Most likely b16 or ls. I have a turbo that I might use but I am wondering if it will be too big for just stock boost. It is a dual ball bearing 63 a/r hot side. 70ar compressor side. So my question is would this turbo be too laggy for a lower boost application, and what should I expect if I use a turbo like this. Thanks!!
Old Aug 7, 2008 | 05:08 PM
Robert Padron's Avatar
Default Re: Too much? (Panda Eg6)
I'm running a .63 trim t3 on the hot side and .60 on the cold. It buids 10psi by 4500rpm. You gotta tell us what type of turbo it is manufacturer and size.
Old Aug 8, 2008 | 08:14 AM
Panda Eg6's Avatar
Default Re: Too much? (Robert Padron)
not sure of the brand.. its dual ball bearing like i said, and .63AR Hot side .70ar cold side 82mm exducer wheel size, 61mm inducer wheel size .
zchs21
Jan 23, 2006 10:08 PM
cbrodac0424
Jul 30, 2004 12:23 PM
Ek00fbp
Oct 13, 2003 10:57 AM
technine
Jun 11, 2002 09:23 PM
Purelude
Jul 24, 2001 08:30 AM
