help with my integra
Old Aug 9, 2008 | 10:38 PM
432boosted's Avatar
Default help with my integra
I HAVE A 96 INTEGRA LS WITH A TURBO I JUST BOUGHT WHEN I START THE CAR IT TAKES A WHILE TO START AND WHEN IT DOES IT IDLES REALLY LOW THEN TURNS OFF I TRIED MESSING WITH THE THROTTLE CABLE AND IT DIDNT WORK IDK WHAT ITS IS ANY HELP WOULD BE MUCH APPRECIATED AND I WAS TOLD IT RUNS RICH SO IM GONNA BUY A AFC FROM APEXI WILL THAT HELP WITH THE FUEL PROB OR SHOULD I SPEND MY MONEY ON SOMETHING ELSE
Old Aug 9, 2008 | 11:49 PM
95delsolz6's Avatar
Default Re: help with my integra (432boosted)
Did you buy the car with the turbo installed or buy the car and then install a turbo? Have you gotten it tuned yet? Do you have a wideband sensor or have a gauge to verify your air fuel ratio?
Old Aug 10, 2008 | 11:29 AM
432boosted's Avatar
Default Re: help with my integra (95delsolz6)
I BOUGHT THE CAR WITH EVERYTHING IT DOESNT HAVE THE AF GAUGE BUT IM THINKING ABOUT BUYIN A AIR FUEL CONTROLLER AND IDK WHERE TO TUNE IT I LIVE IIN WEST TEXAS NOT REALLY ALOT OF TUNERS OUT HERE AND I LOOKED AND THE MP SENSOR NOT HOOKED UP TO ANYTHING COULD THAT BE THE PROB
Old Aug 10, 2008 | 12:21 PM
hotrod99's Avatar
sounds like you just bought someone else's problems,not a wise choice on buying a turbo honda with no ems and your making another wrong move on buying an apexi afc.
Old Aug 10, 2008 | 03:59 PM
DaveF's Avatar
take a good picture of your engine bay, post it up on here. perhaps there is an aftermarket map sensor installed on the car.
for a good cheap wide band sensor/display, check out the NGK AFX wideband (google it )
not sure how close this is to you but.. check out http://www.t1racedevelopment.com
Old Aug 10, 2008 | 10:14 PM
azianretard's Avatar
It might be a vacuum leak, problems with the 02 sensor, could be a lot of things actually
Old Aug 11, 2008 | 07:52 AM
432boosted's Avatar
Default Re: (azianretard)
what things would i check to see if it was a vacum leak
Old Aug 11, 2008 | 08:32 AM
DaveF's Avatar
Default Re: (432boosted)
if it was a vacum leak, the idle would be higher than normal...
just take your car to a shop, and have them look at it. apparently you arent capable of diagnosing any sort of problem yourself. .
Old Aug 11, 2008 | 09:13 AM
432boosted's Avatar
Default Re: (DaveF)
im not dude thats why im asking for help i would like to learn more and eventually will
Old Aug 11, 2008 | 09:59 AM
Mr. Anderson's Avatar
From: A gas station with 87, 89, 91, 92, 93 octane, FL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 432boosted &raquo;</TD></TR><TR><TD CLASS="quote"> SHOULD I SPEND MY MONEY ON SOMETHING ELSE</TD></TR></TABLE>
yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaveF &raquo;</TD></TR><TR><TD CLASS="quote">
good start for a place to spend your money
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 432boosted &raquo;</TD></TR><TR><TD CLASS="quote"> THE M[a]P SENSOR NOT HOOKED UP TO ANYTHING COULD THAT BE THE PROB</TD></TR></TABLE>
doubt it, factory map sensors are often left on the tb b/c most aftermarket ones won't fit on the same spot. Odds are you have an aftermarket map sensor and one way of finding it is tracing the vacuum lines.
Old Aug 11, 2008 | 10:16 AM
rmcdaniels's Avatar
Default Re: help with my integra (Mr. Anderson)
Did you buy it like that? Or did it start doing that after you bought it?
432boosted
Aug 11, 2008 05:55 PM
say bye to my B18
Aug 30, 2007 08:02 PM
krazyhmongboi
Jan 23, 2007 05:15 PM
TEG777
Jul 8, 2005 04:52 AM
Nextelbuddy
Sep 11, 2003 01:46 PM
