weird noise Help (video clip)
I know this might be the wrong section but i figured i might get more response in here.
Well i just swap y tranny for a JDM GSR LSD tranny and after install i hear a loud thump and something of a grinding noise, only on turns.
i haved jack the front end and had it runing in 1-3 gear and no problem i even turn the wheel while its doing 25mph on jack stands no problem. Only does it i guess with load. While the front end was up i put it in 1st and tryed to turn the wheels with my hands and it wouldnt even budge. So is it my axle or tranny??? please help
http://www.youtube.com/watch?v=5tSLVoGbeuk
Is your axles pushed all the way in? Also, it sounds like a bad axle are you certain the axles are still good? It could also be that the joint came out of place and isn't poping back in all the way.
well i just replace the axle....i notice that i have to pull the axel like 1-2 inch just to get the axle nut on.....i bought a new knuckle for a 97 civic and i have a 99 civic could that be teh problem?/
