b20 turbo how many psi?
A Digital Frontier
i was looking into boosting a b20 for my friends car and i saw on hmotors the 96-98 spec motors come with 8.8 compression i wana know how much psi i can boost cause i saw some one on youtube do 15psi tunned on a bone stock b20. any info would be appreciated
Re: b20 turbo how many psi? (sohc sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohc sol »</TD></TR><TR><TD CLASS="quote">the sleeves arnt as strong as ls motor so 15 should b the max on the stock block 10 psi would b alot more safe</TD></TR></TABLE> you have no idea what you are talking about. we need more info on his setup. 10 psi on a small turbo is not the same as 10 psi on a large turbo. different psi on different turbos give different hp. i would look into how much hp a stock block can handle rather than how much psi.
A Digital Frontier
ya i was kinda looking for how much i can push it tuned with a t3/t4 turbo and look heres the video
http://www.youtube.com/watch?v...lated
Re: (MagnaniEG6)
you can run 5psi or 50 psi all depends on the size of the t3/t4 you want and all about the tune. The video above is my coupe when I had a b20 turbo then b20vtec turbo in it.
HELLO,GOOD MORNIN'
Re: (slotec)
A Digital Frontier
Re: (slotec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slotec »</TD></TR><TR><TD CLASS="quote">you can run 5psi or 50 psi all depends on the size of the t3/t4 you want and all about the tune. The video above is my coupe when I had a b20 turbo then b20vtec turbo in it.</TD></TR></TABLE>
is it cool if u pm me ur setup and how much u put down on 13 psi ur coupes sick
