Help on oil restrictor
Old Aug 18, 2008 | 05:06 PM
jchrm80's Avatar
Default Help on oil restrictor
I am just about to install a used turbo kit I bought off of here and I wanted to see if this is an oil restrictor or not? Sorry the pictures arent the most detailed. thanks
Old Aug 18, 2008 | 06:01 PM
eh3 93's Avatar
Default Re: Help on oil restrictor (jchrm80)
Looks like a restrictor to me but disconnect that straight piece and see how big the opening is.
Old Aug 18, 2008 | 06:12 PM
SILVER2K1GSR's Avatar
no doesnt look like it, its the fitting for the oil line on the back of the motor
Old Aug 18, 2008 | 06:20 PM
eh3 93's Avatar
Default Re: (SILVER2K1GSR)
Looks way too small to be the fitting on the block for the oil feed and oil pressure sender.
Old Aug 18, 2008 | 07:31 PM
. a d a m's Avatar
Default Re: (eh3 93)
Unscrew the piece that appears to have teflon tape on it and check and see how big the hole is.
Old Aug 19, 2008 | 10:26 AM
b18 hatch mike's Avatar
Default Re: Help on oil restrictor (eh3 93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eh3 93 &raquo;</TD></TR><TR><TD CLASS="quote">Looks like a restrictor to me but disconnect that straight piece and see how big the opening is.</TD></TR></TABLE>
Old Aug 19, 2008 | 03:08 PM
B R Fittings's Avatar
Default Re: Help on oil restrictor (b18 hatch mike)
Thats not a restrictor.
Old Aug 19, 2008 | 03:48 PM
Default Re: Help on oil restrictor (B R Fittings)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B R Fittings &raquo;</TD></TR><TR><TD CLASS="quote">Thats not a restrictor.</TD></TR></TABLE>
what about the bronze 90 degree fitting it might be one
Old Aug 19, 2008 | 04:08 PM
sohc sol's Avatar
na looks like just an adapter to make the -4n fitting go into back of block or extend it a lil
Old Aug 19, 2008 | 05:44 PM
eh3 93's Avatar
You know what. He's right. You dont have to disconnect it. The opening in the first pic tells it all. Too big.
Old Aug 19, 2008 | 06:22 PM
where can i get a good cheap one
Old Aug 20, 2008 | 07:25 PM
a1320addict's Avatar
double post
Old Aug 20, 2008 | 07:26 PM
What turbo are you using?
Old Aug 20, 2008 | 07:50 PM
Default Re: Help on oil restrictor (a1320addict)
my friend posted up but its for me its sc61
Old Aug 21, 2008 | 07:10 AM
TheShodan's Avatar
Moderator
^^ then no restrictor needed, especially for a turbo like that with a large shaft.
killamike0001
Sep 6, 2007 12:22 PM
teddy_dc2
Aug 10, 2006 06:11 AM
HickamHatch
Jul 27, 2006 07:00 PM
PHOBIA
Jan 18, 2005 07:23 AM
integra-modder
Jul 7, 2004 08:19 AM
