Best A/C and P/S compatible Turbo Kits?
I'm planning on boosting my EM1, I'm not hardcore enough to take the a/c out. So which turbo kit will best suit me? A small turbo will be fine, I just want to put out around 200-250HP.
Location: New York in the summer, South Carolina in the winter
Re: Best A/C and P/S compatible Turbo Kits? (EM1ly)
depends on how much HP your looking to make
entry
-drag
-revhard
-turbonetics
mid
-inline pro (id go with this)
all out
hytech setup like muckmans
full race, afi, peakboost ect ramhorn in AC compatible
entry
-drag
-revhard
-turbonetics
mid
all out
Re: Best A/C and P/S compatible Turbo Kits? (JDMCRX)
its a very tight fit even with a 2.5"
thats my setup
I have the downpipe jet hot coated just for safety- and the lines heat wrapped-
no issues
thats my setup
no issues
I see you are in Cali, are you needing something to pass emissions as well?
We offer 2 different A/C kits.
Here's a dyno of the Tuner kit...
D16Y7 non VTEC
and the street kit
Bone stock Y8
D16Y7 non VTEC
and the street kit
Bone stock Y8
Full Race Stage 1AC kit Contact me for pricing
"EK/EM1 B Series AC Stage 1 $4,454.00( Call/PM/Email for BEST PRICE ANYWHERE!)
Stage 1 AC Turbo Kit is designed for the entry level racer who has no intentions of heavily building their motor, and MUST keep AC. Stage 1 gives great throttle response but does not have the top end pull that is found on a larger sized turbocharger. The stage 1 kit uses a 57 trim turbo for B18B1 and B16A1 engines or a 60 trim on B18C1 and B18C5 engines. Available for B series engines only.
Includes:
-Full-Race AC Manifold
-Full-Race 3" 4-bolt Downpipe
-Full-Race Intercooler 22"x8"x3"
-Full-Race T3/T04E Turbo
-Tial 44mm Wastegate
-Tial 50mm Blow Off Valve
-Full-Race Custom 2.5" Aluminum Intercooler Piping
-Full-Race Oil Line Kit
-Full-Race Vacuum Line Kit
-Full-Race Hardware Kit
-Full-Race Gasket Kit
-Full-Race Silicon Coupler Kit
-Full-Race Hose Clamp Kit
Application Notes:
# AC compatible.
# Must trim PS bracket in order to retain PS.
# Must use 1/2 sized radiator."
Includes:
Application Notes:
# AC compatible.
wrenchin'
1 Post
Re: (Boostfed.com)
used greddy 18g kit. i cant believe the sponsors ***** it up like they do. $4500 for 250whp? you're f-ing NUTS.
i love my 18g kit on my gsr. remove the crappy engine management, get it tuned on crome or whatever, have a 2.5 inch DP made, and be happy for under $1700.
edit: the car isnt slow either. 13.4@107 on ziex 912s with 43 psi in them . full interior, 4 door, full weight GSR with a full sized spare and tools in the trunk.
Re: (I Have an STD)
Ours aren't carbed unfortunately, great price, but won't pass an emissions test more than likely. I would look at a used Greddy or Edelbrock
Re: (I Have an STD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Have an STD »</TD></TR><TR><TD CLASS="quote">used greddy 18g kit. i cant believe the sponsors ***** it up like they do. $4500 for 250whp? you're f-ing NUTS.
edit: the car isnt slow either. 13.4@107 on ziex 912s with 43 psi in them . full interior, 4 door, full weight GSR with a full sized spare and tools in the trunk. </TD></TR></TABLE>
terrible isnt it?
terrible isnt it?
Moderator
Greddy is fine for that power level, especially in Cali where your emissions C.A.R.B demon rears its ugly head. I personally would still use it, and modify a few things such as the downpipe and retune the engine management with larger injectors (this can be done in the future) and go from there.
Re: (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan »</TD></TR><TR><TD CLASS="quote">Greddy is fine for that power level, especially in Cali where your emissions C.A.R.B demon rears its ugly head. I personally would still use it, and modify a few things such as the downpipe and retune the engine management with larger injectors (this can be done in the future) and go from there.</TD></TR></TABLE>
beat me to it... /thread.
Re: (blinx9900)
as for the sponsors posting their kits in this thread, i dont see where they mention that they clear BOTH AC and PS.
I liked my greddy kit on my old car, but honestly, it leaves you yearning for more power.
everyone says, "nah i'll be find with 250whp".
they get their 250whp, its awesome the 1st month, then after that, you see them up the boost or do something drastic.
i was the same way. i even got rid of the car and got an evo. i said "stock is way more than i can handle" yet i still ended up upgrading the hp levels on that car as well.
other than the greddy kit, what else clears AC and PS?
the DRAG kits seem pretty dated, anything new from them?
Re: (Spec R)
why not build your own kit with a meutek manifold? they clear ac and ps, i made good power with mine when i had it... drag/reghard/turbonetics i would stay away from all those kits, they all creep and are dated...
Re: (blinx9900)
For a beginner, a drag kit can be had for like 700 bucks- send the turbo out for a rebuild for a 150 bucks, buy a set of 550cc RC for 150, and maybe 200 dolars in random little things. your at 1200 bucks plus 300 or so for a tune 1500 bucks and your good to go. Maybe even buy a Tial wastegate to avoid creep. Thats just what Id do, and did (except i just purchased a new turbo)
- my setup is 100% reliable, AC/PS fit, and it pulls just fine for a DD
