mac valve with neptune.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">Yes, as long as you get the right valve. There's hundreds of mac valves. </TD></TR></TABLE>
speak the truth
speak the truth
There is a discussion about the MAC valves in the engine management subforum. From what I can see, AEM/ECtune uses the larger 36-series (ideal at 31Hz), and Hondata uses the smaller 35-series (heard they use 20Hz in Hondata). I'd assume you can set the Hz in Neptune, so either should work. I've seen in 3 cases where the 36-series (31Hz) doesn't work for Hondata S300 (20Hz).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile »</TD></TR><TR><TD CLASS="quote">There is a discussion about the MAC valves in the engine management subforum. From what I can see, AEM/ECtune uses the larger 36-series (ideal at 31Hz), and Hondata uses the smaller 35-series (heard they use 20Hz in Hondata). I'd assume you can set the Hz in Neptune, so either should work. I've seen in 3 cases where the 36-series (31Hz) doesn't work for Hondata S300 (20Hz).</TD></TR></TABLE>
