head oiling issue?!
Old Aug 15, 2008 | 11:17 AM
AK94GSR's Avatar
Default head oiling issue?!
i have an lsvtec turbo setup and i was tearing my setup down and found that the cam journals near the tbelt side both have metal to metal type wear on them. i have the golden eagle vtec conversion kit but was wondering if anyone knows what the cause of this could be???
when i rebuild my setup should i get a higher flowing oil pump gear or was the cause from bearing failure and low oil pressure??,
i found no issues with the bearings though
any ideas would help
Old Aug 16, 2008 | 06:19 AM
blkb18's Avatar
Default Re: head oiling issue?! (AK94GSR)
Are you sure the oil orfaces are installed? They sit under those two end cam caps. Also make sure the orings are on them and not damaged.
willfly
Apr 20, 2013 05:57 AM
Dontoh
Apr 29, 2011 09:50 AM
91integraLSVTEC
Jan 29, 2009 11:19 AM
dfoxengr
Mar 9, 2007 08:34 AM
EdBoon
Jan 6, 2004 12:09 AM
